Question about Balboa Instruments Duplex Digital Panel 2 Pump
My Balboa 500Z-Series Hot tub has been working fine for 6 months. Then today, without warning the lights started flashing and I could not turn them off from the light button. Additionally a code "Pr" appeared on the screen. I switched off the power for several minutes then switched back on and "--" appeared on the screen and the lights continued to flash. I pressed a number of different combinations and the message 5r appeared. This message does not appear on my owners manual. The water level is at the appropriate level and cannot think of a reason why this would take place other than a mechnical failure. Any ideas? With thanks, Craig Vogel
Hello!
I have a question about my Balboy 500Z. When the water is heated the motor pump is still running that means the pump runs all the time without interrupt even the water has it's temperature. Now my question: is it possible to turn of the pump? thank you for your quick answer! Greetings Beat from Switzerland
Posted on Oct 23, 2015
4 Suggested Answers
  • 40 Answers
SOURCE: Hot tub ran fine till we moved it the balboa
pr will remain on for 3 minutes if still not starting
check fuse on circuit board
Posted on Mar 29, 2011
rockmeister
  • 2047 Answers
SOURCE: I have a Balboa Instrument
Hello there, what i think is the problem with your unit is the control board. The control board is usually responsible for the general functions of the unit. If the control board has a minor problem it would affect the entire units functionality. Although the problem should be minute and repairable so you wont need to replace the entire board which could be very expensive. this is evident from the unit still coming on and starting the pump. Simply get the entire board taken and and checked for the irregularities on the board.
hope this solution has been helpful?
Thank you for visiting FixYa.
Posted on Aug 07, 2011
SOURCE: I have just refilled by
Priming can be done many different ways depending on thetubs design. Some tub manufactures provide bleed valves located on the plumbingjust beyond the pump and heater unions. Some pumps have a bleed valve locatedon the pump. If there are no bleed valves then you will have to release theunion nuts to allow the air to escape.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
Hope that helps.
Posted on Sep 12, 2011
Great lakes hot tub
Hi, I am not a hot tub expert and I don't know what PR status is or what PL on the display means . However I did a quick search for you and have a web address that might help you find a solution.
http://www.spacare.com/troubleshootingguideforspaandhottubs.aspx
Hope it helps you
Regards
Steve
Mar 27, 2014 | Garden
No temperature display cant set temperature
Located behind the access panel there is a grey box that is the spa pack. Open that up with the 2 screws on the top of the pack. There is a small glass fuse on the circuit board. One of those fuses is most likely blown. If that is not the culprit you need a new topside control. More than likely it's the fuse.
Mar 04, 2013 | Jacuzzi Balboa R574 System for 1 2 Speed...
I have just refilled by hot tub with a balboa 500z pump. After refilling it the pump is working fine but the jets are not. The dr light has come up. Please can someone help me bleed the pump to get it...
Hope that helps.
Jun 12, 2011 | Balboa Instruments Duplex Digital Panel 2...
Balboa vs500/501/502 gs500/501/502 I just refilled spa yesterday and now I'm getting error codes HL and dr both indicate low flow issues, The water level was re-filled to where it's always been. Any help...
A lot of times you can get an air lock as the spa fills. All you need to do to fix this is open the drain valve for a few seconds till it runs just water and no air. Or start the pump wile the drain is open. This should fix your problem. Good luck.
Sep 04, 2010 | Balboa Instruments Duplex Digital Panel 2...
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
I have the Balboa 500Z pump heater kit. Its hooked direct to a mighty iron ( 120v) recirclulating pump. Ever since it was new, I keep getting lack of water vflow errors ( dr, then dy ) I have plenty of...
I have a 6 month old Balboa 500Z. I have noticed that the filter system tis running all the time 24/7. I have reset the filter cycle to run for 2 hours { F2 }. It still is running all the time. It dose not seem to make a difference what I set the cycle for it just keeps running
Dec 06, 2009 | Balboa Instruments Duplex Digital Panel 2...
Balboa Instruments Duplex Digital Panel 2 Pump Logo
1,913 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
