Question about Pyramid - America: 4 Channel 1800W America Series PB-1860 Car Audio Amplifier
Pyramid america 1800 watt amplifier has power but no sound. whats the problem?
    Top Expert:
  • Pyramid Master
  • 2,931 Answers
It doesn't work.
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
pyramid america 1800 watt amplifier has power but - helpful-j2fqtt4x4km4a1x1cbly0mof-5-0_9.png
Posted on Feb 10, 2018
3 Suggested Answers
Hazardsneon
  • 100 Answers
SOURCE: amplifier
Actually I meant to post that as a solution instead of a request. Let me know If you would like to know more.
-Andrew Hawkins
Posted on Apr 11, 2008
SOURCE: Re: Pyramid PS-36kx power supply buzzer sounded,red light came on
Hi! I saw your question, and maybe this will help. I also have a Texas Star 100w amp, and this same power supply. Even though the nominal draw for your equipment is way below the rated amp flow of the power supply, when you key up, and the output on the amp is at max, you are drawing the limit of your power supply! Try running this setup at a lower linear output. You don't need the full 100 watts to get out! 60-80 watts is aplenty! You should start at a low output, and slowly increase the output(while keyed up), untill the power supply starts to complain.(buzzer/light). This is what your limit will be. The only other cure, is a MUCH bigger power supply. Unfortunately, I cannot afford a 60-90 amp supply, so this is what I am forced to do to use the one we have. Also,keep your cb's output very low when using the linear amp. These amps are supposed to get a low signal from your radio, or the linear amp is overdriven. (noisy and unstable. Hope this helps you! 73's to you! jimsjinx
Posted on Dec 03, 2011
Wiring diagram for road master 100 watts equalizer Thanks
Nov 02, 2016 | Pyramid 403G Seven Band Power Booster...
Why does the red light come on when i hook the power wire up to my car amp?
Could be fried, or connections are wrong and its not getting a good ground. If you're not getting power most likely its fried. Check fuses etc. Take it to a brandsmart and have them test it
Aug 26, 2014 | Pyramid - America: 4 Channel 1800W America...
Electrical schematic for pyramid pa-1000x
Jan 22, 2012 | Pyramid PA1000X 1000 Watt PA Amplifier Car...
Need advice on setting up amp with my two speakers.
This is hard to explain and what needs to be done is wire in parallel both subwoofers. This website will help just put in the amount of speakers and amount of ohms each and it gives you diagram.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=81#results
Mar 24, 2010 | Pyramid ZPA150 Car Amp
I have a 300 watt amp, but i just bought 12 gauge wire why wont it allow sound to come from my 12'' sub
There is no reason even if the wire was to small it would still allow ssound.make sure you have good connections.
Nov 08, 2009 | Pyramid 906 300 Watts (peak) 10 Band...
Pb1281x pyramid crystal 2ch mosfet amplifier 1600w what size fuze i got a 20amp in it it blows when i got it terned up
Hello sunshanel,
You did not say what you have the amp connected to and what the impedance load is. It is only stable at 4 ohms and if a lower impedance is connected, say 2 subs in parallel, it would try to produce more power when you turn it up and would most likely blow the fuse. 20 amp sounds right for the amp. The power rating of 800 watts per channel is peak power, not RMS, and many low-end manufacturers tend to state bigger numbers in the ratings.
Hope this helps.
Apr 26, 2009 | Pyramid PB1281X Car Audio Amplifier
Amp over heating and cutting off
sounds like the Impedance of the speakers does not match that of the amp, therefore the output stage of the amp is trying to compensate, driving the amps too hard and eventually causing the thermal cut out to activate. Check the ratings on everything are compatible before you start sending it off to be fixed.
Mar 22, 2009 | Pyramid PB736GX Car Audio Amplifier
Car Audio & Video Logo
147 people viewed this question
Top Pyramid Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Frank Mangiapane
Level 1 Expert
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
