Question about Amana BX21V
Refrigerator portion is not working - Amana BX21V
  • 1,772 Answers
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Posted on Jan 02, 2011
Electrolux refrigerator not cooling
Is your freezer side working fine? If it is, and it is just the refrigerator portion of your appliance, then I would check the damper switch/door that is between the doors. The freezer actually sends its cool air into the refrigerator portion to help cool it.
Aug 20, 2012 | Electrolux EI26SS55GS Stainless Steel ...
I have HRF 340h, and i m facing cooling problem in one portion,
may be evaporator fan is not working or the air flow from the freezer to the fridge is blocked.
May 14, 2012 | Refrigerators
Kenmore side by side Refrigerator top portion is not getting cold. The freezer is working and the bottom portion of the refrigerator is cold but not the top portion of the refrig,
the refrigerator simply by transferring the cold air from freezer via circulation fan the temp controls tells the fan to circulate cold air until the thermostat is satisfied I would check to see if the fan is blowing on most models I have seen its located in the left rear wall closest to the freezer above the top shelf
May 02, 2012 | Kenmore Refrigerators
The bottom freezer portion works, but the top portion is not cooling at all.
Check the refrigerator coil to see if it is iced over. If so you will have to defrost the coil. Also make sure the fan for the evaporator is working. This should fix your problem. Please leave feedback. Thank you
Aug 24, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerator portion of our side by side maytag is not getting cold enough freezer portion is working fine
see if your fan inside the fridge is working , if it is moving to slow or not functioning at all, try to replace it
Nov 14, 2009 | Maytag MSD2756G Side by Side Refrigerator
Top refrigeration portion smells like something is burning, warm temperature on top portion, bottom freezer appears to be working, unplugging and switching circuit breaker does not resolve problem, smell...
I need to let you know that your refrigerator may fall under a consumer alert. It is possible that the lights are remaining on while the doors are shut and can result in property damage. The issue is the light melt the plastic and damage the refrigerator, food and possibly smoke damage. If this is not the case please let me know and I will assist you if there is something other that this causing the problem. Thanks Sea Breeze
Oct 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Help! In 2006 I purchased a used RV with a dometic model 2408 refrigerator that did not work. After reading up on Absorption refrigerators and repair facilities I had it rebuilt by RV Mobile in Everett,...
The evaporator coil is usually located in the freezer compartment, and there are ducts with dampers that send cool air to the refrigerator. It sounds to me like that may be your problem. It seems that if you move the appliance around a little, (cleaning it and the like), then for a short period you start to get a semblance of cooling. Hope this helps
Sep 10, 2009 | Refrigerators
Refrigerators Logo
93 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
