Question about Car Audio & Video
I want to install rear view camera on my dodge gr caravan 2002 wire routing?
  • schwabw Jan 02, 2011
    I should have said it is a wireless unit,to get from licence plate
    on Caravan reargate to backup light circuit
    the monitor can be plugged in cig lighter
    thanks
    President:
  • 2,047 Answers
Usually there are various brands of cameras which can be fitted into cars. But since you just need the layout i assume that you need a rough diagram of where the wires are supposed to go through. The wires run from the back lights to the inner brake light where the main control is usually located. From the main control the cables run along the top of the doors to the screen display which is located in the front segment of the car. The diagram below should give you a guide to it.I want to install rear - rockmeister_3.png
Hope this has been helpful?
Posted on Jan 02, 2011
  • 942 Answers
Yes you need wire routing wherein the wires coming from your car battery should be traversed to its location you chose. Make sure the wires is long enough to reach that point...
Posted on Jan 03, 2011
How do i replace the PCM on a 2002 dodge caravan 2.4L engine?
First set park brake,locate PCM in van ...Compare new PCM with old to be sure new one is correct part..You will small tube of dielectric lube..WEAR SAFETY GLASSES..,Disconnect negative battery cable...wipe and blow dust/contamination from around wiring harness plugs...Remove plugs from PCM...,Remove old PCM..lightly lube connecter pins with cotton swab..,plug in wiring harness connectors..re-connect battery cable...Complete..............BROOKS..
Oct 08, 2014 | 2002 Dodge Caravan
Where is the trans contro module in 2002 Dodge Gr Caravan
It's located behind the front bumper on the driver's side. You need to disconnect the battery, remove the left front wheel and remove enough of the retainers for the left front wheel well [plastic] shroud, to move the shroud out of the way. This gives you access to the TCM [transmission control module aka transmission computer] Diagram linked below. See
2002 Dodge Grand Caravan 3 3 TCM Location diagram Google Search
May 15, 2014 | 2001 Dodge Grand Caravan
Diagram for serpentine belt routing dodge caravan 2002 3.3l
Click on the following free direct Link. It has the Serpentine Belt Diagram for your 2002 Dodge Caravan 3.3L.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
http://www.2carpros.com/car_repair_information/year/2002/make/dodge/model/caravan/2002_dodge_caravan_drive_belt_routing_diagram.htm
Apr 01, 2010 | 2002 Dodge Caravan
2002 dodge gr caravan code p0135 and p0456 what do these mean
135 is O2 Sensor Heater Circuit (bank 1 sensor1)
456 is Evaporative Emmission Control System
very small leak detected
Feb 13, 2010 | 2002 Dodge Grand Caravan
2002 Dodge Caravan - Remove Stereo
Theres a fewa around...but one that helps me with things like that is...This site should help you!! Good luck!!
helpfulvideo.com/video/.../dodge-caravan-radio-removal.html
Nov 08, 2009 | 2002 Dodge Caravan
I am looking for the rear brake line for 99 gr caravan it has about 7 bends in it and i cant seem to find part number or anything about it
You obtain the line straight and have to make the bends while installing. measure the lengths of the old line and get a length that closely matches. NAPA should have your line without costly dealer part.
Aug 06, 2009 | 1999 Dodge Grand Caravan
Rear wiper motor not working
Remove the wiper arm. Lift the hatch up. Remove all related trim around the hatch. Unbolt the wiper motor, and install in reverse order.
May 28, 2009 | 2002 Dodge Grand Caravan
Need diagram of heater hose route from engine to rear heater
Hi there;
I found a couple pictures; I wasn't sure of your engine size or if you needed the rear heater aplication so I picked the most common ones & attached them.
Good luck; Hope this helps
Farrout!
Mar 17, 2009 | 2002 Dodge Caravan
Rt taillight lens damaged; '98 dodge gr. caravan. how to unplug?
hello release tailgate latch and open tailgate remove screws holding tail light ok depress lock tab on side of connector that the wires go into so press then pull next ,ok to change bulb the round things that look like turn dial on a timer in the kicthen just turn counter clock wise thanks and good luck
Feb 14, 2009 | 1998 Dodge Caravan
Guessing it is stuck in diagnstic mode 1998 dodge gr. caravan 3.3
there is a module that needs reprogrammed,this happens all the time
Feb 03, 2009 | 1998 Dodge Grand Caravan
Car Audio & Video Logo
158 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
