Question about HP LaserJet 1320 Printer
1320nw prints blank pages. Replaced cartridge removing plastic strip on left of cartridge and orange clip on rear of cartridge. Attempted print from both PC and Mac computers. "print preview" reveals desired document. No error messages or lights indicated
    Genius:
  • 1,570 Answers
Just uninstall and reinstall the printer software to resolve corrupted file.
Posted on Jan 02, 2011
Printer printing but nothing appears on page?
Hi, Make sure that the cartridges are not blank. Clean the print head properly and check the nozzles. You may have to replace the cartridges.
Oct 17, 2011 | Canon PIXMA MX310 All-In-One Printer
We just replaced the ink cartridges and they were recognized by the printer but when we submitted something to print, it did not print anything.
Too many possibilities! Is it printing blank? as in it processes the print job and ends up with blank page? In that case you probably forgot to remove the protective plastic tapes on the cartridges
Jul 03, 2011 | Office Equipment & Supplies
Hi! I just changed my print cartridge (HP LaserJet- C7115X, ink 15x) and the printing quality is still low! It's as if it's still running out of ink, however the cartridge is brand new. Please help!
Did you remove the strip that the printers ship with? If the pull tab is still in then there is typically enough toner to print a few pages and then it fades out. Remove cartridge and check on left and right hand sides for a plastic loop usually orange. The instructions would have been in the box.
Mar 23, 2011 | HP LaserJet 1320 Printer
Replaced a printer cartridge type 106 with same. Everything was done according instruction. The printer printed several pages and now will not print anything but a blank page. what needs to be done to...
Check to see that the toner cartridge does not still have a "Pull Strip" on the cartridge. or Remove the cartridge and gently rock the cartridge a few times in your hands and re-install.
Jun 25, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
HP 1320NW PRINT IS FADED ON THE LEFT SIDE BUT OK ON THE RIGHT,SWITCHED PRINT CARTRIDGES BUT STILL THE SAME
Try taking out the toner cartridge and using a soft cloth to wipe the narrow window that is above where the cartridge sits inside. The window gets toner on it and blocks the laser path writing to the drum.
Feb 05, 2010 | HP LaserJet 1320NW Printer
Dell printer printing blanks pages
? check that you did not leave the pull strip on the cartridge ?
Aug 11, 2009 | Dell Inkjet 720 Printer
Printer performs as if printing yet gives only blank pages
Check whether you removed the yellow strip of the cartridges. remove the upper unit and check when head cleaning the ink goes throw the ink tube. if not you can sure that the head cleaning unit is to be repaired.
Aug 10, 2009 | Epson Office Equipment & Supplies
Hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Jun 30, 2009 | HP LaserJet 1320 Printer
Hardware Error 0502
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Sep 20, 2008 | Dell A940 All-In-One InkJet Printer
Hp laserjet 1320
1. check the cartridge on another printer to check if the cartridge is OK.
2. If cartridge is OK, print a test page on the printer. If the paper comes out properly, the mechanism turns properly, does it have any print out even a faint one.
Try these and keep posted.
Feb 19, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
109 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
