Question about Kenmore Dryers
How do I get element out of heater box on kenmoore 110.89683800. Box is out of dryer. Took out only screw I could find but still won't budge.
    Sergeant:
    Novelist:
  • 185 Answers
The last one I did it just slide out from the bottom........ Take a look at the new heating element and see if there are any holes or supports that you are not seeing on the old one that could be holding it in...... Hope this helps Good Luck
Posted on Jan 02, 2011
When i was removing the heating element on my whirlpool dryer i accidently took the top part off also and now i can.t get the part to go back in the hole
I'm assuming you mean the heater box has an upper and lower half. The top rear of the heater box usually has a metal clip that prevents the heater box from accidentally coming out of the vent hole. To re-install the heater box, it can be tricky/frustrating. You must lift up on the front of the box which will lower the rear, make sure the clip is in the hole, and then "sort of twist/shove" the box back until you feel it slide inside the vent hole. Use a headlamp to see what you're doing and to visualize the fit. Hope I helped you!
Aug 14, 2015 | Whirlpool Dryers
How do I get to the heating element?
Not sure on your particular model but most, that I have replaced, are accessible from a back panel. Hint: Before you start... use a camera (digital) to record your steps, so rebuild becomes easier. Also to the preventive maintenance while you are taking things apart. disconnect the exhaust, unplug the unit, clean all parts of lint, and finally check the belt. A DIY person can handle this task. Also before you begin check for the availability of the replacement element, which will give you some hints as to its installation.
Feb 09, 2011 | Kenmore 800 6983 Electric Dryer
How do you replace the heat element on a whirlpool LER8648 dryer?
Before replacing the heating element, check first the continuity of the thermal cut-off and the high-limit thermostat located on the heater box, the resistance of the heating element, and the continuity cycling thermostat located on the blower housing. Replace the heating element only when it reads open. Replace both the thermal cut-off and the high-limit thermostat should any one of them is found open. The cycling thermostat must have continuity between its thicker terminals; otherwise, replace it.
All of the above components are accessible through the rear of the dryer. Remove the rear panel by removing the screws securing i to the dryer cabinet. Replace the heating element by removing the screws attaching its housing to the heater box then securing the new heating element housing in place.
May 28, 2010 | Whirlpool Dryers
How do i change the heating element.
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Apr 13, 2010 | Amana DLE330RAW Electric Dryer
How to find the heating element on the Kenmore 80 series... Model 67832794... trying to replace myself but can't figure where the heating element is located
remove the back of dryer,unplug,look to the right and you will see the heater box,the lower half is the heating coil,remove the 2 wires and 2 screws and pull the heater off,also you need to check the heater box fuse located on the upper left side fg heater box-mike
Feb 19, 2010 | Kenmore 63942 Dryer
Dryer runs but does not heat up. do not know how to change the heating element or where the fuse box is.
remove the back of dryer,the heater box and fuse are to your right,the fuse is on the left side top and you can remove the heating element by removing the 2 screws on the lower bottom of heater box-mike
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Instructions to replace faulty heat element on a whirlpol electric dryer
If the model number is correct, the heating element is replaced by following these steps:
1. UNPLUG the dryer. Dangerous voltage still exists inside the unit even when it is shut off.
2. Turn dryer around so you can access the rear panel. Disconnect the dryer exhaust vent hose.
3. Loosen and remove all the screws around the perimeter of the rear panel. Remove panel and set aside.
4. The heating circuits will be located on the right hand side (as viewed from the rear) with the heating element located inside the heater box.
5. Remove the mounting screws that hold the heater box in place and disconnect the electrical connections (make sure you annotate where the wires go).
6. The entire heater box comes off with the element inside. Loosen the screws on the outside of the heater box that hold the element in place. With the screws removed, the element will slide out the bottom of the heater box.
Now...if the dryer is running but not heating, have you confirmed the heating element is bad? There are several factors that can cause these symptoms. Please review the following link before you assume the element is the cause:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
If you haven't done so already, it may be a good idea to double check the source voltage, followed by a check of the Hi-Limit Thermostat and Thermal Cut-Out (TCO). All these components can factor into the same symptoms you may be experiencing.
If you have any questions, please post back and let me know. I hope this information is helpful to you.
Dec 05, 2009 | Whirlpool LER5636P Electric Dryer
How to replace heating element on dryer model #96282100
This is a fairly simple procedure. Just follow these steps:
1. UNPLUG the dryer. Dangerous voltage is still present even with the dryer turned off.
2. Turn the dryer around so you can access the rear and remove the exhaust vent hose.
3. Locate and remove the screws around the perimeter of the dryer back panel and remove panel.
The dryer heating circuitry will be located on the right hand side (as viewed form the rear). The heating circuits consist of the following components:
Heating Element - (part number 660982)
*Thermal Cut-Out (TCO) - (part number 279769 includes the Hi-Limit Thermostat).
*If either the TCO or Hi-Limit Thermostat is determined to be defective it is recommended that you replace BOTH parts at the same time. That's why they are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
The heating element is located inside the heater box. The TCO is located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit thermostat will be located adjacent to the heating element terminals.
Searspartdirect.com has an excellent exploded view diagram of all these components. Just type in your model number and locate the following under the "bulkhead" section:
TCO/Hi-Limit Thermostat - Item 1
Heating Element - Item 14
Hi-Limit Thermostat (by itself) - Item 34
The reason I mention all these components is because if you have not confirmed the heating element to be defective, you may actually have a blown TCO or Hi-Limit Thermostat. Its easy to assume a bad heating element if the dryer fails to heat, but it may or may not be the cause. Just some additional things to consider, that's all. These components cost less than a heating element too. If you have determined the heating element is bad, then continue with the following:
4. Disconnect the leads to the heating element and locate the screws that hold the heater box in place.
5. Locate the screws on the outside of the heater box that hold the element in place. You may also have to remove the TCO and Hi-Limit Thermostat.
6. Once the screws are removed, the heating element will slide out of the heater box. The element fits tight and it may require a little effort.
7. Once the defective element is removed, install the new one by sliding it inside the heater box. Make sure you align the screws holes.
8. Reinstall the remaining components and reinstall the heater box.
The rest is self-explanatory.
NOTE: A good heating element will read approximately 9 to 13 ohms. Make sure you disconnect any leads before taking any measurements to ensure accuracy of your readings.
The following link explains a good portion of what I've already explained to you, but it may help as well:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention the section that discusses proper air flow. The majority of all dryer heat related problems are attributed to poorly installed, kinked, clogged or crushed exhaust vent ducting. If you haven't thoroughly inspected the dryer and ducting recently, now may be a good time to do so. Otherwise, any components you replace will fail prematurely. Not to mention, a clogged dryer is also a fire hazard.
If you have any questions, please let me know. I hope this information is helpful to you.
Oct 20, 2009 | Dryers
Procedure to replace heating element on 84152 electric dryer
This is a simple repair. Just follow these steps:
1. UNPLUG dryer. Dangerous voltage is still present even with the dryer turned off.
2. Remove the dryer vent exhaust hose and remove the back of the dryer.
3. The heating circuits are located on the right hand side (as viewed from the rear). The heating element is located inside the heater box. Simply remove the mounting screws on the heater box and remove the two wires on the heating element terminals. NOTE: You can leave the two remaining components (Thermal Cut-Out and Hi limit Thermostat) connected on some models. If you need to remove them in order to remove the heating element make sure you label the wires.
4. Locate the mounting screw(s) on the outside of the heater box that hold the heating element in place.
5. With the mounting screw(s) removed the heating element will slide out of the heater box.
6. Insert new heating element, making sure you avoid touching the coil and align the screw holes so you can reinsert the mounting screws.
7. Re-install the heater box and any remaining components.
Now...are you sure you have a bad heating element? Just because a dryer does not heat, does not necessarily mean the heating element is bad. The following link explains:
The most common fail item that causes a dryer heating circuit failure is a blown TCO caused by poor dryer ventilation. Just something you may consider.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 22, 2009 | Kenmore 84152 Electric Dryer
Kenmore Elite He4 Dryer Model Number 110.85872400 won't heat up and dry clothes; husband thinks it is the heating element but is having a hard time gett it out
Before assuming you have a bad heating element, read through the following link:
Most dryer heat related problems are attributed to poor ventilation which, in turn, causes the dryer to overheat to the point of failure. More commonly the Thermal Cut-Out (TCO) fails. The component acts as a fuse and must be replaced if bad. In addition, if the TCO is determined to be defective, it is recommended that you replace the Hi-Limit Thermostat at the same time. Both these components work in conjunction with the heating element and are mounted on the heater box. The TCO is located on the end opposite the heating element terminals. The Hi-Limit Thermostat is located adjacent to the heating element leads. These two components are often sold as a kit. If you fail to replace both of them you can experience premature failure of the component you do replace.
Pay particular attention to the section that discusses proper dryer ventilation. If you haven't checked or cleaned the exhaust ducting any time recently, now might be a good time to do so . A dryer left in a clogged or poorly ventilated condition will cause repeated failures in the heating circuit. Not to mention this creates a fire hazard.
If you read through the link and determine that you have a bad heating element, follow these steps to remove:
1. Unplug the dryer and remove the lower panel under the door.
2. Remove the lint screen from the dryer door.
3. Remove the blower fan housing vent cover.
4. Disconnect and label the component wiring on the heater box.
5. Loosen the mounting screw on the heater box front support.
6. The entire heater box, with element inside, should slide out of the dryer.
7. There should be a couple of mounting screws on the component side of the heater box that you need to remove and the entire element slides out.
If you still have questions, please let me know. I hope this helps you.
Jun 12, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
