Question about LG LRTBC1825T Top Freezer Refrigerator
I have an LG fridge, mod# GR621R with water coming into it from back of light assembly and also took out middle shelving bracket where water gushed out after turning off for a day . drain tube at reat bottom is clear and nothing in drip tray , could it be problem with tube at top near freezer ? thanks
5 Suggested Answers
  • 534 Answers
SOURCE: moisture dripping from temperature control hood model KTRS21MFAL0
possible that condensation drain line is clogged. This line drains the water from the freezer when it goes into defrost to a small pan loscated above the compressor where when it gets to the pan the heat from the compressor running evaporates the mosture.
Posted on Apr 16, 2009
  • 93 Answers
SOURCE: Water accumulates inside the refrigerator, Kenmore, Mod. 71194100
You get to it from the freezer. Remove the back wall in the freezer and you will see it there. Unclog it with some wire or check to see if it has ice over it.
Posted on Sep 14, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Refrigerator Mod ED27DQ side by side
Yes, I'm not sure what part you need so I am sending the parts manual. Your model number should be longer but this manual covers most parts you will need. Click Here=> ED27DQXANO3 page 4 will show the parts and page 5 shows the part number you need. Just tell me what you need and I will help you find it. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Posted on Feb 17, 2010
richroth
  • 9472 Answers
SOURCE: How to access the drain tube on LG GR621R fridge from the top??
You should be able to get to it thru the top of the unit.
Posted on Nov 13, 2012
I am getting water on the shelves of my fridge
If you have a top mount fridge and water is collecting on the top shelf in the middle you have a clogged drain and need to flush it out. The drain is in the back of the freezer and on the bottom. lmk if you need more help!
Aug 04, 2013 | Bosch Refrigerators
How to get glass out of shelves for cleaning
most shelves have the glass attached to the side brackets,, empty the shelf, and at the back of the fridge,, you'll see slotted rails that go top to bottom,, tap the shelf bracket upwards and it should come right out,, be careful,, once off the glass may come out too,,
Jun 13, 2011 | Refrigerators
Fridge and freezer are set at 7 and the fridge is cool but not cold and the freezer has not been able to freeze a box of freezepops that have been in (2) days, The back wall of the freezer has frost...
http://www.partselect.com/PS303781-GE-WR51X10055-Defrost-Heater-Bracket-Assembly.htm?SourceCode=1&ModelNum=HSM25GFRASA
WR51X10055 is the part number of the defrost heater and bracket assembly. Item #230 in the diagram. On this unit it is a plug in unit.
It is relatively easy to replace. Remove food from the freezer section, remove shelves, remove back panel. Unplug refrigerator. Defrost the unit by either leaving the door open to the freezer section or you can hurry it up with a hair dryer. After it is defrosted, plug in the new defrost unit, plug the frigerator back in and reattach the back panel, shelves and food.
Jun 10, 2011 | Hotpoint HSM25GFRSA
Replacing Defrost Heater and Bracket in Freezer Section of Fridge
I ended up having to remove things in this order: all shelves, ice maker insert, ice maker top ice tray, ice maker lower motor housing, shelving support rails (2), rear evaporator coil cover. This exposed the evaporator coils (which were already dry since the fridge had been off for two days) and most importantly, the defrost heater element below the coils. The heater element was easily unplugged from it's two connectors. I tested the unit with an ohm meter and it indicated it was open (infinity resistance). I then knew it was bad. I replaced it with a new unit and put everything back together in reverse order taking care to use the same screws. The fridge appears to be back in working order.
Oct 18, 2009 | GE Refrigerators
Hi i have a fridge freezer which is a samsung sl39wj1/ xeu and i need help coz it keeps coming up with f5
water in fridge on shelve from freezer.( I am assuming) Have defrosted and cleaned fridge and freezer removed all visable ice and water. Took off vent in fridge no ice. what else can I check out before calling repair man?
Dec 31, 2008 | Refrigerators
GE TCS18 Bottom Freezer
Clogged Freezer Drain it is. To clarify, pull out the fridge, remove the smaller square metal panel (about a third of the way up the fridge in the middle) with 4 screws. Behind it is a black drain pipe system. Remove two screws and remove drain pipe (takes some pulling to detach the seal). There is a silver 3" long pipe that goes into the freezer itself. Remove this, clear it and replace. Take the black pipe and pluming, remove pluming block from the black pipe and blow through it. Run warm water through it (most likely where the clog is) then before reconnecting it to the black pipe, blow through the black pipe to make sure there is no clog there. Reattach pluming, screw it back in, replace the panel and there you have it!
Feb 23, 2008 | GE Profile PDS22MHR Bottom Freezer...
Refrigerator leaking water out
being in the uk, i don't know this appliance specifically so take this as guidence. there are two places where water can come from. at the rear of the fridge there should be a gully at the bottom of the evaporator wall - the part that frosts up. in the middle of this gully is a drain and this is likely blocked. push something flexible down it and check blockage is cleared by pouring a small amount of water in the gully and see it flows freely away. good idea to occasionly pour a small amount of dilute bleach down it now and again to keep it sweet. the other place for water to come from is if some of the contents of the fridge are touching the back wall. when it defrosts the water tends to divert onto the shelves
Apr 02, 2007 | Kenmore 74522 Top Freezer Refrigerator
LG LRTBC1825T Top Freezer Refrigerator Logo
137 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
