Question about GE GSS25JEMWW Side by Side
Freezer Problem: Only part of it is cold
Until recently my refrigerator (GE side-by-side) was working just fine. Then the ice-maker turned out to be clogged up again with ice, which I could only "fix" by pulling the ice-maker out and knocking the ice loose.
Three days later the freezer is malfunctioning with the top part being basically at room temperature while the bottom end is still OK.
Any ideas of what may need fixing?
  • 1 more comment
  • ben_onbass Jul 14, 2008
    Thanks for the reply. Reading the offered solution I took off the back
    panel to look for the drain line. I removed some minor dust ball.
    Nothing much changed. Then I pushed a polyethylene tube up where the
    drain line attached and used a hair dryer to blow air up that tube.
    Still no change.
    I unplugged the fridge, let it completely defrost and plugged it back
    in. After running six-plus hours it still only the bottom of the
    freezer gets cold, and the icemaker is merely a lukewarm water
    dispenser. Any other suggestions?
    BoB
    One more comment: I don't have a thermometer to pin down the temperature at the bottom of the freezer, but it appears to me that it is not lower than the refrigerator side.
    BoB
  • ben_onbass Jul 15, 2008
    Thank you very much. Much of the evaporator had much frost on it. Top and bottom of the evaporator were frost free. Neither fan is running.
    Should I look for thermostat problems or replace the fans?
    Thanks again.
    Ben on bass.
  • 4,889 Answers
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Posted on Jul 09, 2008
  • eagle338
    eagle338 Jul 14, 2008
    Ok, inside your freezer you will see the back panel, just take the screws out and remove it, then you can see your evaporator coils, notice the frost pattern. How much of the evaporator coil has frost on it?
    A normal evaporator coil should have a thin layer of frost on the entire coil.
    Also check to make sure your fan in the freezer is turning fast and also your condenser fan in the back next to your compressor is also turning fast, you just need to take off your bottom access panel in the back to see it.
Ge Gsh25jsxnss side x side fridge is not getting cold, took plate off & damper works fine, I don't see ne kind of fan, it goes straight 2 the freezer near the ice maker. freezer is cold & working fine
Evaporator fan motor has probably failed. p/n WR60X10185
It is located in the freezer section, behind the back panels inside, and under the icemaker. Remove the screws on the bottom panel in the freezer, remove the ice maker, auger motor, and panel. is is about center of the freezer.
Jun 22, 2016 | GE Refrigerators
I have a GE refrigerator model # GSH25KGMB WW. It is a side by side with an ice maker and water dispenser. We have had it for about 9 years now. The ice maker hasn't been working right for about 6 or 7...
you could have several problems.
Since you mentioned your ice maker not working right - first check to see if your ice maker is hot (be carefull it can burn you if it is hot) - it is possible for an ice maker to hang in the heat cycle of the cycle producing excessive heat in the freezer. If this is the case unplug the ice maker and/ or just replace it.
The refrigerator gets it cold from the freezer so if the freezer is not working right, you'll soon notice it in the refrigerator side.
You can also check to make sure the evaporator fan motor is running(in the freezer) and the condenser motor(at the compressor) as well.
Also check the back panel of the freezer for excessive frost build up.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Our GE Adora Refrigerator's ice maker isn't working properly
Perhaps your freezer isn't set cold enough - or your freezer door seal is not sealing correctly and the ice cubes are melting in the bin and sticking to one another and the spiral screw that delivers the ice.
Mar 14, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Ge side by side model tfx27pfx. Ice maker not
Your defrost drain hole is clogged. Turn the fridge off. Defrost the drain hole in the freezer. You will be fine until it does it again.
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not cooling/making ice.
At this moment I think that you need to unplug the refrigerator and remove the ice maker to stop the leaking. Any extra water inside the freezer will make it harder for the defrost to remove the moisture. While the ice maker is out I want you to look to see if water is still leaking out the fill tube that feeds the ice maker tray. If it is then we found the reason. If not then we need to check some of the parts on the ice maker. Let me know what you find, Thanks, Sea Breeze
May 20, 2009 | GE PSS26PSS Stainless Steel Side by Side...
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
GE GSS25JEMWW Side by Side Logo
160 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
