Question about Peavey Valveking Vk100 Guitar Head
My Peavey vk100 head is running through a Carvin Legacy 2x12 cab. On the clean channel there is an inconsistent popping sound. It will happen loudly for a few seconds, and then not at all for a while, and then happen again. This sound doesn't happen when I switch to the distorted channel. Could I be mismatching the impedence, or using a bad cable? Does my amp need new tubes?
  • Peavey Master
  • 5,603 Answers
You may simply be overdriving the clean channel and causing it to "flat top" . See if it occurs when you back the gain down a bit. New tubes PROBABLY will not help and be a waste of money. You may be unconciously playing harder during the popping episodes. You cannot hear level variations smaller than about 3 Db BUT the electronics will sense much smaller variations. You could gently tap the tubes with a lead pencil to listen for any pops... NOTE: tubes can be slightly microphonic so some sound from tapping is normal.
Yes, a cable can be noisy and not show itself when using intentio0nal distoprtion... try another to verify it is not the problem.
Posted on Jan 02, 2011
# 1991 peavey classic chours 2x12 scorpion speakers one speaker makes a buzz noise only on a high e note only sometimes -if i want to replace the speaker do the front grill come off to remove spekaer
Normally on older Peavey amps the grill is on a frame attached to the face held on with velcro. I suspect you have something vibrating against the speaker if it's only one frequency. Once the grill is off it may be apparent.
Also on old Scorpions and Black Widows Peavy has a piece of foam in the hole in the magnet to keep junk from getting in the speaker. Over time it crumbles and opens that hole, but even worse can get it the gap and freeze the voice coil. I always suggest cleaning it out while the speaker is out of the cab.
Nov 12, 2016 | Peavey Music
No sound
Not user serviceable. Take it to the repair shop.
Feb 02, 2014 | Peavey Valveking Vk100 Guitar Head
I own a Peavey Valveking vk100 and when using the distortion channel on high gain it makes a weird whistle-like noise (not a feedback sound). The strange thing is that if i lower the gain, the sound...
Sounds like Tube Microphonics to me...
Change the 12AX7 (I guess) for that channel for starters.
If not, some condenser went crazy.
Nov 12, 2017 | Music
No Power after Valves glowed bright
This could be a transformer failure. Take it to the repairs shop.
Jun 08, 2013 | Peavey Valveking Vk100 Guitar Head
Can i connect 2 (2x12) cabs rated @ 4ohms each to my avt50 head?
No, the ATV50 head is rated for 4 ohms total. Using both 4 ohm cabinets at once will fry your amp.
Feb 12, 2013 | Marshall Amplification Music
HOW TO REPLACE BLOWN FUSE PEAVEY VAVALE KING 100 HEAD
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Jan 26, 2013 | Peavey Valveking Vk100 Guitar Head
Peavey Valveking head strange feedback.
Sounds like one of your tubes going bad and becoming microphonic...
Google "Microphonic Tube" for additional info.
Oct 25, 2012 | Peavey Valveking Vk100 Guitar Head
Peavey vk100. v3 filament burns out when amp is turned on
V1, V2 and V3 heaters are in parallel and they are fed through the 6L6 heaters that are in series from the 30V DC HTR supply. If V2, V1 or neither are plugged in there is over current to the heaters and therefore over voltage to damage V3.
Aug 11, 2017 | Peavey Valveking Vk100 Guitar Head
In my Valveking VK100, fuse F203 is designated as 13.15AL250V Where can i obtain this fuse for repair?
This means you need a 15 ampere, 250 volt fuse, 13 is just an identifier for part replacement. You can find this fuse at any Radio Shack or other electronic store on the web. It may be a plug in type or it may have pigtails on it that will need to be soldered in to place.
Hope this helps.
Feb 10, 2011 | Peavey Valveking Vk100 Guitar Head
Peavey Valveking Vk100 Guitar Head Logo
221 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
