Question about WD 40 Company Wd40 10016 16oz aerosol wd 40
WD-40 aerosolcan will not spray, why? how to fix?
    President:
  • 1,996 Answers
There is an arrow or mark on the edge of the can that the nozzle should be pointed towards for correct spray. Tryt removing the spray tip from the can and blowing compressed air through it if you have the tools to do so. But you may have a defective can. Happened to me once with a new can and I called the company. They sent me a free one in the mail that week.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jan 06, 2011
Audi 500e radiator fan makin a high pitch annoying noise,hw do I fix it?
Sounds like a bearing in the electric fan is bad, replace fan motor
Mar 16, 2015 | Audi Cars & Trucks
Tip
I Want My (Digital) Rights!
In 1958, the Rocket Chemical Company realized that selling WD-40 for public use as a lubricant spray could be a very profitable endeavor. Today, WD-40 widely available in hardware and discount stores. There are five delivery systems for the product: WD-40 aerosel is the traditional delivery format; the WD-40 Smart Straw is a can with a permanently attached straw; the WD-40 No-Mess Pen allows you to use the product while on the run; WD-40 bulk/non-aerosol is offered in gallon and 55-gallon containers for large jobs; and the WD-40 Big Blast provides a wider spray pattern and larger can size.
Although WD-40 has a very distinctive smell, there is nothing dangerous in the product. The odor is simply the result of a fragrance added during the manufacturing process. The primary ingredients in the product are mineral spirits, liquefied petroleum gas, and mineral oil. The exact formula of WD-40 is a highly guarded trade secret, however.
For automotive repair, WD-40 has many uses. It can drive moisture out of the high- and low-tension electrical components of a motor engine and loosen nuts or screws. If you're trying to keep your car in top shape, WD-40 is also good for restoring and cleaning padded leather dashboards in vehicles.
Around your home, WD-40 can fix noisy door hinges, keep scissors working smoothly, loosen rusted screws, stop electric fans from squeaking, and lubricate the tracks in your windows to make them easier to open. Many people also report that spraying WD-40 on hand tools is a good way to prevent rust damage. Although it seems hard to believe, WD-40 is also a great household cleaning product. It is good for removing lipstick or tomato stains from your laundry. You can use it to remove stubborn duct tape residue, clean splattered grease off your stove, keep glass shower doors free of water spots, clean stainless steel sinks, and camouflage scratches in ceramic or marble floors. WD-40 will even take oil spots off concrete driveways.
dont remember to rate this tip...
thank you !
on Aug 16, 2010 | Audio Players & Recorders
Tip
What is WD 40 ?
on Aug 14, 2010 | Price Pfister 43-OOXC Bathroom Faucet,...
My Intermatic T103 Indoor 120-Volt 40-amp timer emits a constant peeping sound
Intermatic T103 is mechanical timer with moving gears.
Timer makes audible sound when tripper clicks on-off, but it should not make constant noise unless gears are causing noise.
Turn off power and spray WD-40 on gears and see if problem continues.
WD-40 vapor is extremely flammable hydrocarbon when sprayed, and should not be sprayed on live electric circuits.
If problem continues, turn off power, pull mechanism out and spray WD-40 on plastic gears of clock motor.
Open following links for illustrations of clock motor and removing mechanism.
http://waterheatertimer.org/images/WH40-005-gears-350.jpg
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Aug 12, 2011 | Intermatic T103 Indoor 120-Volt 40-amp...
The door ajar light stays on all the time. I tried to push in on the doors, but nothing works. Please help me John M
this is caused by the door ajar switch sticking. easiest and cheapest way to fix this is to spray a generous amount of wd-40/enforcer/pb blaster or like spray chemical into all the door latches. this will free up the sticking switch. spray it into all your door latches since we dont know which switch is sticking and spray a lot of wd-40 onto them
Sep 08, 2010 | Ford Explorer Cars & Trucks
Tip
WD-40 works great as starting fluid!
We all have at least one can of WD-40 lurking somewhere within our households. Great stuff for fixing almost anything in need of a shot of lubricant. What most people don't know is that WD-40 also works terrific as starting fluid when dealing with that hard to start lawn mower, car, or motorcycle. Just spray some in the carburetor intake and your engine will fire right up - even if it has been sitting for a long time and there's stale gasoline in the carburetor making it reluctant to start.
WD-40's combustible makeup not only helps hard to start engines run, but its light viscosity lubrication also helps to lubricate valve guides and piston rings that are lubrication starved from long periods of non-use.
As with any flammable material, common sense precautions are essential: don't smoke or use WD-40 near an open flame, and do not crank an engine over while spraying WD-40 into the carburetor inlet.
on Dec 02, 2009 | Motorcycles
Gear lever stiff and does not return to the centre
Hi, Permanant fix, take to garage and get them to replace link shaft on gear change mechanism. Or temp fix, get a tin of WD 40 with the plastic pipe that can be pushed onto the spray nozzle. Get a chopstick or simillar. Put chopstick down side of gear rubber gater. Do this by pulling blue rubber gater away from gear knob and gently inserting chopstick down into gater. Put the WD 40 plastic pipe down gater alongside the chopstick and spray a good amount. then roll the chopstick around to another possition and spray more WD 40. repeat until you have done it four or five possitions covering all round. Job done.
Jul 28, 2010 | 2006 Mitsubishi Colt
Its actually a 87 dodge aries k car. My gear
I have an 87 aries wagon that it happened to. Spray lots of WD-40 on it. It is usually due to a rusty/corroded cable, and wd-40 should loosen it up. Take the cable off of the lever, and see if you can shift it out of "1st gear" if you can't or if it's tough, spray some WD-40 in/on the cable, and hold the clutch in, and shift to random gears a bunch of times. it may take a few sprayings, but if the cable isn't too far gone, you can do that. it wouldn't hurt to spray it on the lever where it pivots.
Jul 27, 2010 | 1988 Dodge Aries
One of the buttons is sticking on my Nord Stage (the amp button). How can I fix it?
FROM DOCTOR FIX . SPRAY WITH WD 40. THEN CLEAN UP WITH A PAPER TOWEL, ALL SPRAY.
WD 40 IS NOT A OIL, IT IS A STRIPPER.
Jul 07, 2009 | Clavia Nord Stage 88 - Digital Stage Piano...
Fix the tension on Seatbelts: How do you remove the cover to
WD-40 will stain the belt I would recommend using silicone spray
spray the whole belt both sides the silicone will dry
Mar 03, 2009 | 2005 Ford F 350 Super Duty
WD 40 Company Wd40 10016 16oz aerosol wd 40 Logo
64 people viewed this question
Top WD 40 Company Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a WD 40 Company Saw Expert? Answer questions, earn points and help others
