Question about Sony PlayStation 3 Slim
I need help changing my nat settings from strict to open for my ps3, i have a bt home hub router, and my upnp is enabled, is there anything else i can do???
  • 708 Answers
PS3
You will have to open the following ports in your BT router
Make sure the firewall is disabled in the Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Posted on Jan 02, 2011
Need to change NAT type from moderate to open. possible upnp problem?
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : Open Router Setup by typing http ://192.168.1.1 ( Default password is admin )
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
Dec 22, 2010 | Linksys Wireless-G WRT54G Router
Change nat from strict to open and settings for upnp
NAT STRICT
Step 1 : Connect Router - Computer ( Wired )
Step 2 : Open Router setup by typing http://192.168.0.1 on the address bar of the internet explorer
Step 3 : The Default Password is admin
Step 4 : At the top Click Advanced
Step 5 : On the left Click Firewall Settings
Step 6 : Enable DMZ
Step 7 : give the IP Address of the Xbox/PS3/Wii in it
Step 8 : Uncheck the option Enable SPI
Step 9 : Click Save Settings
Step 10 : Test the connection
let me know if this works
Regards
TOM
Nov 17, 2010 | D-Link Xtreme N DIR-655 Wireless Router
The NAT on my Netgear Dual Band WNDR 3300 is set to strict and is causing issues with XBOX Live, how do I change this setting to moderate, or below? I went to the website where you change the settings of...
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Aug 24, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Ive connected my xbox 360 through wired connection to my modem/router and it tells me my NAT settings are strict and to enable upnp but i dont know how to enable it?
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Jul 30, 2010 | Zyxel Prestige 660HW Wireless Router...
Need to change my nat setting from strict to open can't find anywhere on belkin wireless router settings
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
Jun 23, 2010 | Belkin Wireless-N Wireless Router with...
Change NAT from strict to open for Xbox live
OK NOW THAT CAN ONLY BE CHANGED by the manufacturer i believe , or the internet supplier , because mine ( virgin broadband ) varies sometimes , when i play some games depending it sometimes says strict, open , or moderated so its more likely nothing to do with the settings.
Mar 24, 2010 | D-Link DI-614+ /DWL-520+ Router
Ok my nat type is strict and i am trying to change to open
You want the NAT open for X-box ?
For X-box you will need to open some ports on the router.
Also you will need to reduce down the MTU on the router to 1365.
That will work.
for this you will need to open the router set up.
Click here for more info about x-box and router settings
Dec 09, 2009 | Actiontec Computers & Internet
Bt home hub change my nat from strict to open
you will need to change some settings on the router.
reduce the MTU. If the MTU settings is1500 then change 1365.
also you will need to open the some ports on the router.
Click Here for more info
Nov 22, 2009 | Computers & Internet
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
NAT set to strict
upgrade your router to the latest firmware that can be found here:
http://kbserver.netgear.com/products/WGR614.asp
after upgrading the firmware, press the reset button for 30 seconds, then reconfigure the router. you will need to re-enable upnp if it is disabled, and open up ports UDP 88 UDP 3074 TCP 3074. i would also reserve the ip for the xbox and if all else fails set the xbox as the dmz host.
hope this helps,
trin
Nov 16, 2007 | NetGear WGR614 Wireless Router
Sony PlayStation 3 Slim Logo
191 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
