Question about D-Link DSL 200 (DSL-200) Modem
Please, help me!!! I try to install D-Link DSL-200 drivers, and Windows XP SP3 reports me "error loading newdev.dll". Where can I download the correct version of this file?
  • 3,400 Answers
Try this http://support.dlink.com or try calling them (877)453-5465
Posted on Jan 02, 2011
Hi I dont have installer cd or prog for DSL 200 for win xp sp3.
The DLINK website does not allow me to give you a direct link to the drivers, so here's the "how To":
  1. Go to http://support.dlink.com.au/Default.asp;
  2. On the left site of the website, choose "DSL" in the first menu (A), then 200 in the second menu (B) and click on the blue "GO" button (3);
  3. Click on the + near Downloads and click on Downloads for DSL-200;
  4. Now, before downloading the drivers, check for the revision on your modem. Under the unit, you will have a sticker, where you may find H/W : A.5, VA5 or H/W B.5, VB5 etc. This will tell you the "Revision" of your modem.
  5. click on "Drivers" in the section corresponding to your modem, then download the latest drivers. The drivers should al be compatible with Windows WP Sp3.
I hope this helps.
May 16, 2011 | D-Link DSL 200 (DSL-200) Modem
Tip
Remove BT Voyager 100 Modems drivers with the newdev.dll error
The newdev.dll is something to do with SP3 being installed, however if you try with SP2 you will get the Can't Open Bitmap and still you will be frustrated.
If you have SP2 installed you will recieve the error <Can't Open Bitmap> this is when you use the older newdev.dll (2146). If you install SP3 you will get the error <you need admin rights to run uninstaller> this is with the newest newdev.dll (5512) that SP3 installs
http://rapidshare.com/files/261766010/newdev.dll_error.zip
If you download this file it has both NEWDEV.DLL versions, you will need to restart you PC in safe mode to replace the DLL file then restart, see if you can get it to work I didn't and gave up in the end I even tried the installer for the origonal modem also included all without any luck.
In the end I removedall traces of the driver using the jv16pt v1.0.0.124 FREEWARE version, the 2009 version is about £25 but if you like the free one the latest will impress you as you can remove services and control panel shortcuts.
Hope this helps you I will find another fool proof method soon I believe that if you use doctor100.exe from the AOL CD you can remove the driver however I don't have one so I can't try this at the moment.
30 Trial Version link
http://www.macecraft.com/downloads/jv16pt_setup_hb.exe
After you have installed this trial version it will place a buy me now icon to the desktop I recommend that you do there are many other tools that perform similar functions, CCleaner from Piriform is probably the best freeware alternative that deals with registry and applications but doesn't give you the control of the power tools.
http://download.piriform.com/ccsetup227.exe
It is also available for the U3 stick drives now at the suppliers website so you don't have to create your own I use this loads on PC's that I fix to remove all the **** in the cache, cookie and almost all temp files that clog up your regsitry.
http://www.ccleaner.com/download/builds/downloadbinu3file
on Jan 08, 2010 | Microsoft Windows XP Professional for PC
What does "RUNDLL Error loading newdev.dll" and
newdev.dll is the Windows file that is responsible with the recognition of the hardware and the loading of the drivers - an absolutely critical file. This file is severely corrupted and the only way to fix that is to perform a Repair install.
Dec 15, 2010 | Dell Computer Refurbished OPTIPLEX SX270...
Unable to install for winxp
that means its not compatible.Check your modem which windows are required to use it.
Feb 18, 2010 | D-Link DSL 200 (DSL-200) Modem
DSL200
Do what you need most. You have to choose yourself whether you require DSL200 or SP3. I can only tell you how to remove SP3 from your PC. Goto start button control panel, add remove programs, Change or remove programes and on top select show updates check box in the list below you will fine windows update Windows XP service pack 3 just click on remove. Further, once you are done with installing your DSL you can once more try installing service pack 3 and see wether both work in harmony or not.
Jul 25, 2009 | D-Link DSL 200 (DSL-200) Modem
Newdev.dll error and asking for admin rights on bt modem 105
If you have IE-8 installed, then uninstall it and it will start working.
You can uninstall IE-8 using this command in the run dialog box:
"C:\WINDOWS\ie8\spuninst\spuninst.exe
Regards,
Ashish
Jun 20, 2009 | Computers & Internet
DSL-210 for Windows XP
upgrade your windows xp, drivers are not required to use the router on your computer if you are using the windows xp. or you should have a look at your lan drivers first  or if you are trying to connect your router using the usb cable, please try to update your usb drivers.
for drivers download  http://ftp.dlink.ru/pub/ADSL/DSL-210/Drivers/DSL_210_Driver.zip
Jan 24, 2009 | D-Link DSL 200 (DSL-200) Modem
I need DSL-200 in Windows Vista
i need DSL-200 installation on windows vista.
please help me.
warm regards
Jun 04, 2008 | D-Link DSL 200 (DSL-200) Modem
Dll file have error
Hi alexistech, the wininet.dll & newdev.dll are windows fies. You can try this link to fix your *.dll files.
http://www.dll-files.com/dllindex/dll-files.shtml?normaliz
Luck!
If this helps, please let me know.
Need more help just post your questions here.
Mike
Apr 17, 2008 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
D-Link DSL 200 (DSL-200) Modem Logo
567 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
