Question about John Deere 4020 Gas & Diesel Tractor Radiator
HOW DO I GET INTO MY PTO ASSEMBLY.? the loader won't move up or down
  • charper486 Jan 03, 2011
    the lever has come unattched to the rod that makes the loader or PTO work
    Problem Solver:
  • 4 Answers
Is it a sealed component? if it is only your dealer can fix it
Posted on Jan 03, 2011
  • dmacduff1443 Jan 03, 2011
    it also could be hydrolic failure or a pressure leak
My exmark Quest stopped in the middle of mowing my lawn. The engine runs the pto works. But mower will not move. Why won’t mower move?
I would check the transmission drive belt. It has either jumped off, broke or is stretched out of shape.
Oct 15, 2017 | Garden
1949 M farmall :pto will not engage
When you pull the rod does it fell like anything moves inside the tractor? If not, remove the four bolts holding the pto in the rear frame. Pull out the pto assembly and what you most likely will find is shift lever broke and not shifting the pipe sleeve to spline to the transmission shaft. Pull it out and look.
Nov 29, 2016 | Farmall Garden
John Deere Frozen PTO Mechanism
begin by checking every mechanical part that rotates . I do not find a manual I can look thru for the possible problem .
Mar 12, 2017 | John Deere Garden
What's wrong when PTO won't engage? On my
should go from the switch to the safety switches to the clutch
Apr 01, 2012 | Briggs & Stratton Garden
How do I change the belt on my ammco 4000 lathe?
I am a brake lathe technician.
To change the drive belt on an Ammco 4000, you must first remove the 90 degree angle PTO (power take off) gear assembly which is driven off the back of the big pulley. Two small allen head screws hold it tight.
Pull the PTO gear assembly out of the disc-feed gearbox. If there are colored shims between the gearbox and the PTO assembly, you must make sure not to loose. If they drop off, be sure to replace them with a dab of grease.
Rotate the red knob at the back of the machine and the motor assembly will unlock and rotate upwards. Replace the drive belt.
To adjust the drive belt tension properly--loosen the 3/4 inch nut on the back of the machine, and the motor will drop down. Tighten the 3/4 inch nut and then rotate the red knob back until the belt is taught.
Replace the PTO gear assembly--making the rotating part with the protruding pin is centered on the big pulley. Tighten the allen head cap screws.
Turn on the machine. If the PTO is making noise--you have not correctly is correctly. Repeat the centering process until the machine runs without rattling or vibration.
Sep 28, 2010 | Ammco Combination Disc/Drum Brake Lathe
When hit switch pto won,t come on
check the 2 wire conection under the frame near the pto clutch, motor off of course. Make um tight.
Apr 30, 2010 | Oregon Scientific Electric PTO Clutch for...
PTO Tension JD 155C
Look between top of deck and bottom of machine for a rod coming from the rear topside of deck and going up to bottom of machine.Where it connects to machine there is a small pin you must pull to disconnect it.Once done loosen locknut and turn collar in,away from nut,3 or 4 turns to give PTO lever more pull.Tighten locknut,put rod/collar up and over crossbar and into hole it came out of,install pin.You may need to move PTO lever as if you were going to engage blades to help collar line up with hole.
Jan 09, 2010 | John Deere 48 in. EZ Trak Power Flow...
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
John Deere 4020 Gas & Diesel Tractor Radiator Logo
94 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
