Question about Sony BDVE570 Theater System
For the Sony BDV-e370, I have an optical cable from TV for cable sound, and it works fine until I change the channel, then no sound and if I switch back to the Sony input the TV says no signal. Any ideas?
5 Suggested Answers
SOURCE: Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
Posted on Jan 15, 2008
SOURCE: No sound through TV
In case you connect the System to a TV set using the Scart Connector, only the video signal is terminated, Audio is actually not wired inside the SB100 Scart connector.
Sound will only be amplified through the system itself (through the satelites and Sub) it can not be utilized as a stand-alone DVD player.
So after connecting your surround speakers the problem will be solved
Posted on Jan 19, 2008
welcomejee
  • 10594 Answers
SOURCE: Sharp LC-32D44
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one.
Go to menu of home theater system and enable surround.
Need further help, let me know please...
Posted on Oct 26, 2008
smarthome2
  • 1114 Answers
SOURCE: Macbook Pro DVI---> HDMI + Digital Optical Out = Problem w/ Sound
On the Sony The HDMI takes "priority" over all others, that's why you loose audio. If you run your DVI/HDMI to the TV and optical to the soundbar that would fix your issue. If your TV does not have Multiple HDMI inputs, you can get a DVI/Component adapter for your MBP then run it to the TV, or, If you have to have HDMI just to have HDMI, you can get a 2:1 HDMI switch and still have optical to your soundbar. Make sense? If youneed more help, just post a comment and I'll help some more.
Posted on Jun 23, 2009
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
Sony BDV-E370
From page 68 of this manual: "Contact your Sony dealer or local authorized Sony service facility."
Mar 02, 2013 | Sony BDV-E370 Theater System
Sony BDV-E370 locked
From page 68 of the manual: "Contact your Sony dealer or local authorized Sony service facility."
How can I fix the echo between my TV speakers and my dvd/blu ray player home theater speakers when watching a movie. Also, in the settings menu on the BDV E370 system do I have to select speakers only...
Easy, disable the TV speakers or turn its volume down.
http://static.highspeedbackbone.net/pdf/Sony%20BDV-E370%20Manaual.pdf
Page 36 tells you how to sync the sound to the picture but you really shouldn't have the TV speakers competing (in stereo) with the Sony. (Page 56).
A) The TV speakers are probably inferior to teh Sony's
B) When you balanced the speakers during setup there was no 'with-the-TV-speakers-on' option. The image up front would suffer by adding an unaccounted for sound source.
Aug 11, 2011 | Sony BDV-E370 Theater System
I need the three digit code for my Sony BDV-E370 home theater remote controller.
The RM-ADP053 comes in the box with the BDV-370 and is preprogrammed with the codes to operate that unit. The manual can be found at Sony at this link.
To reset the remote control back to factory specifications, press the POWER , TV/VIDEO , and VOL- buttons simultaneously.
Jan 18, 2011 | Sony Rm-adp053 Remote Control
Sony BDV 370 home cinema system and Sony 40hx703 television. The home cinema plays disks etc. through the cinema speakers. But will not play television sound through the cinema speakers it is connected...
You need to use a HDMI 1.4 Cable and it needs to be connected to to an HDMI socket with an ARC (audio return channel). Alternatively you can connect using an optical cable (TOSLINK).
Aug 29, 2010 | Sony BDVE300 Theater System
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
I bought the sony bdv e500w surround sound and hooked up a optical audio to my tv and that is a sony bravia but it will not work with the surround sound when i hook it up using regular audio cords it works...
im having the same problem, except im connected via audio components and hdmi...cant get sound through the speakers when the TV is on, it doesnt make any sense.
Feb 14, 2010 | Sony Audio Players & Recorders
Optical digital cable connection ?
It only works through DVD setting
Jun 20, 2009 | Sony STR-DE545 Receiver
Sony BDVE570 Theater System Logo
172 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
