Question about Lowrance LMS-337CDF GPS Receiver
Lowrance LMS 337
Bought in 2006. Had a problem with the module... sent back to manufacturer for warranty and was replaced... new one worked for remainder of 2007 boating season and for one week in May 2008. In July unit functioned then "position lost" turned unit off and checked all power and module connections.. turned unit back on and got "module not responding" Unit has not worked since. Love the unit when it works but so far it has not been reliable. Any help would be very much appreciated Les Marston Edmonton Ab. 780-446-5780
  • 13,433 Answers
I wonder if the module has failed again, have you tried reseting the device?
I'm looking into this but I suspect that repairs are required again.
Posted on Jul 09, 2008
  • Ekse Jul 09, 2008
    You must power your gps antenna seperate and have the 120 Ohm terminators on both sides of the network for your setup to work properly, here is a neat little self help guide from lowrance: http://www.lowrance.com/LowranceNet/LowranceNet.asp
    Go down to the bottom and click on LowranceNet Designer and just follow the instructions and drag and drop what products you have.
Can i replace my 330c head unit with the 525c using the same wires antennae etc lowrance
Hope its not to late, before you replace (buy a new one) call Lowrance. I have a 525 and working through some problems and they advised me that they would replace my unit for $200 no questions asked. To answer your question not 100% positive but I did see a recent question where Lowrance lost his unit and sent him the 525 as a replacement and the connections were different. I believe my 525 has a 5 pin system with one notch. Does yours have a external gps module? The 525 does!
Mar 01, 2010 | Lowrance Lms 525c Df 5" Df Sonar...
I purchase a lowrance LMS-520C about 18 months ago. The depth gauge cuts in and out. It works for a while then defaults to 3.3 feet while trolling. Can you point me in the right direction to find the...
Quite often those transducers go out. Not 100% sure but would bet money on it. Call Lowrance customer support and see if the offer any more advised but more importantly see if they can replace your current one as a replacement instead of you having to pay full retail price. I purchased a new gps module through customer support and saved $150 off the normal retail price. Best time to call customer service is at 8:15am central time when the lines are turned on!
Feb 28, 2010 | Lowrance Lms 520c 5" Screen Color External...
LMS 332c Power cycles on own
i've repaird this by installing a secondary powerswitch and disconnecting the power switch on the keypad. It's an involved repair but it can be done.
Jul 13, 2009 | Lowrance LMS-332C GPS Receiver
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
Lowrance lms 330
have a lowrance lms-330c the depth no. keep changing from hi no. to low no. can not stop it,,, will not show true depth,,, can you help?,,,where can i send it to get it fix?
May 29, 2009 | Lowrance LMS-330C GPS Receiver
I need a manual!!
you can find the manual here,
www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS339cDF_iGPS_0152-011_011206.pdf
Hope my info solves your problem,
Thanx for using fixya.....
Oct 02, 2008 | Lowrance LMS-332C GPS Receiver
GPS module not responding
check the power connections to the antenna
Aug 23, 2008 | Lowrance LMS-330C GPS Receiver
GPS Module not responding
i just got it back from Lowrance and they replaced antenna and it works, but for how long is anybody's guess. The technician at Lowrance told me the antenna should be at least 3 feet from base unit and he thinks that is problem, because mine is only 2 feet. Why doesn't it say that in manual, if true and why doesn't MarineMax install it properly. MarineMax just gave up trying to help me, even though it was under their warranty. They just care about the sale and their installation was shoddy at best with wires hangiing all over the place. I decided to take care of it myself, so we will see.
Nov 11, 2007 | Lowrance LMS-332C GPS Receiver
Keeps blowing fuses
It has a short in the wiring which is "not user fixable". I think the wires are crossed. Take it back, they need to repair or replace it. I suggest you replace it. Take the GPS with you show you can show them the problem. If you bought this on line call Lowrance and find the nearest repair center. Repair it yourself and you loose the warentee.
Aug 21, 2007 | Lowrance LMS-480MDF GPS Receiver
Lowrance LMS-337CDF GPS Receiver Logo
543 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
