I need a user manual for Venus VW600E washing machine since I dont know how to operate it.
5 Suggested Answers
  • 113 Answers
SOURCE: i need user's manual
try googling it
Posted on Apr 29, 2009
  • 19 Answers
SOURCE: i have a venus vw600b front loading washing
NOTHING TO WORRY PUT YOUR WASHABLES INTO IT AND CLOSE THE DOOR AND SET TIMER ACCORDING UR NEED
Posted on Aug 05, 2009
caroldon
  • 17130 Answers
SOURCE: NEED SETTING WASHING MORE THAN
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
The slow inlet flow and clogged draining can slower the time of the wash and so both the inlet and outlet must be cleaned and flushed.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Aug 09, 2011
  • 6277 Answers
SOURCE: i wnt to knw da
I'm so sorry but this forum is not able, nor in a position, to supply any type of manual, parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 26, 2011
Looking for a Samsung WA13G7Q1 washing machine user manual
u can get that manual from below given link
http://www.manualsmania.com/download.php?link=9bf2da2386f59b40b986333f91ad7463356fd759
Dec 14, 2011 | Samsung Washing Machines
I wnt to knw da operation proceedure of venus vw600e vnus washing machine
Manual
John C.
Aug 26, 2011 | Washing Machines
NEED SETTING WASHING MORE THAN 1HOURS VENUS VW600E WASHING MACHINE
Aug 09, 2011 | Electrolux Washing Machines
I need to know how to operate venus washing machine fully automatic because teh signs on the switchs are not much familiar
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and helping for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 24, 2011 | Washing Machines
I need a user manual for bompani bo 02727 washer machine
Sir,
i have a bompani W/M BO 02727
can i hav manual- i dont know how to operate proper?
Jan 03, 2011 | Washing Machines
Plz help me i need venus automatic washing machine user manual
did you try manuals online heres is a pdf of it for you hope this helps
www.user-guides.co.uk or here is another site u can try
www.user-guides.co.uk/.../venus/venusautomatic/venus-automatic-washing-machine-user-manual.html
Jul 05, 2010 | Washing Machines
Need a manual on Kitchen AidArtisan espresso machine KPES100PM, that I can print out Lars
HELLO THERE: PLEASE TRY THIS OK? and dont forget to rate this for me it helps me out so i can help you all out more best regards mike User manual KITCHENAID - User guide KITCHENAID - operating instructions ... KITCHENAID, user manual, user guide KITCHEN, KITCHEN AID, Washing : Washing Machine, ... user manual KITCHENAID MACHINE A ESPRESSO ARTISAN - operating instructions , ...safemanuals.com/brand-user-guide-instructions-owner-manual/KITCHENAID - 53k - Cached
Aug 20, 2009 | KitchenAid KPES100PM Espresso Machine
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Washing Machines Logo
221 people viewed this question
Top Washing Machines Experts
