Question about Cycling
I have a Campy 10 Speed Shifter, running with SRAM S60 wheels, it causes some problems when upshifting
    Guru:
  • 347 Answers
If you are running a SRAM or Shimano Cassette, then the spacing will be ever so slightly off. If you want to have precise clean shifting then you need to either replace the cassette body with a Campy one and replace the cassette with campy or get a 10-speed conversion cassette such as those from American Classic. Campy spacing on a shimano/ Sram spline.
The wheels in and of themselves should not make any difference.
Another trick for perfect shifting, make sure that your rear derailleur and shifter match - Campy to campy, Sram to Sram as examples.
Posted on Jan 02, 2011
I have Campy mirage 10 sp and the rear deraileur shifter ( the right shifter) will skip gears while shifting down 23 to 11. Often I can hear the mechanism making multiple "clicks" on a single...
I would lube everything and check the derailleur adjustments and cable tension. Some Campy chains are 'notchy/clunky' all the time. It's just the way they are. If the bike is low mileage most likely nothing major is wrong. Check the derailleur hanger too just in case you dropped the bike and bent it or something. The shifter 'G' springs will wear out before the derailleur. When the springs are worn, the shifts will be imprecise and will jump from gear to gear without shifting. One thing with Campy stuff...it DOES take awhile to break in. Unless the shifting is horribly off, I wouldn't worry about it - just ride it more - and see what happens. Mirage is a good product, I think inline with Shimano 105 stuff.
Sep 12, 2011 | Campagnolo Mirage
How do I replace the cable in a Sram 3.0 Comp twist shifter?
You enter that question verbatim into a search engine and it will bring you to the same resources we would point toward.
SRAM.com has many resources, too. This one might work out.
http://www.sram.com/sites/default/files/techdocs/SL_3Comp_MRXComp_Ins_2_03_0.pdf
Aug 02, 2011 | Sram 3.0 Comp 7-Speed Twister Rear...
On my ROAD bike could a Sram/Truvati XX or XO (crankset 42/28-cassette11/36) work smoothly with Sram red doubletap Thank you.
To use Sram Red Shifters with such a wide range rear cassette requires a Sram 10-speed MTB rear derailleur such as an XX or X.0, it will work without problems with your red shifter.
Because it is a road bike, i suggest leaving the road crankset and front derailleur in place. If you need low gearing I suggest a compact front crankset.
If you need to use a mtb crankset, attept to use the road front derailluer with it.
Mar 11, 2011 | Sram X-0 XO REAR DERAILLEUR MTB ATB LONG...
Changing a cable on a sram twist shifter
You should be able to push the cable back on its self, as long as the shifter is set in the relaxed position. Then it will be a case of threading the new cable through the shifter housing.
Mar 12, 2010 | Sram Attack 9-Speed Twister Mountain Bike...
I have campy record ultra shifters the rear shifter does not 'click' anymore on the upshift so i don't know when i have pushed it enough to change gear
Hi, there is a ring nut on the outside of lever where you attach it th bar that you can turn to activate the click shift, or else there is a screw, try it in different positions as you are going on guesswork and feel otherwise
Jan 04, 2010 | Campagnolo Record 10-Speed Barend Bicycle...
How does the break cable go through the shifter?
Go to parktool.com/repair and click the brake levers of the bike to bring up a list of brake-related info. Select brake levers, which is the first on the list. The Campy levers and cable are the second topic in the article. There are pictures.
Nov 19, 2009 | Campagnolo Chorus 10 Speed Short Cage Rear...
Replacing Attack's rear derailleur cable
Stop everything! Do not take the shifter apart! Go to the rear derailleur and look where the cable is attached. There is a bolt with an allen key head, it is an 8mm. Losen off the bolt. REFER TO PARKTOOL.COM
Apr 12, 2009 | Sram Attack 9-Speed Trigger Mountain Bike...
Cycling Logo
119 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
