Question about Samsung SP50L3HX 50" DLP TV
We turn the tv on and the screen doesnt turn on and on the power button the word lamp constantly flashes when the tv is turned on
    New Friend:
  • 90 Answers
It means your lamp is getting old and may burn out and you sould replace the lamp.
Posted on Jan 03, 2011
How to fix Samsung HL72A650C1FXZA DLP TV with no sound, no picture, bright screen with lamp light flashing?
Check the bulb ballast board. It's the board that the wires from the bulb connect to. That is most likely causing the Sounds like the main board is the culprit for most of the problem. The picture problem can be the color wheel not turning. The lenses in front of the bulb should be taken out and cleaned too.
Oct 12, 2016 | Samsung Televison & Video
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I got the 'lamp needs replacing' message. Ignored it. Now my tv screen is black when you try to turn it on and the blue button on the power button flashes?
You haven't replaced the lamp at time. Replace a new lamp along with its ballast and make a lamp time reset. If you wish to get more details about the lamp replacing procedure to Panasonic PTVs, check this link.
Feb 05, 2013 | Panasonic PT-44LCX65 Television
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
TV switched off and lamp is flashing red
you need to buy a new lamp you can order them on line or order from like a Bestbuy,no way around it
May 12, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV Does not Turn on
it sounds like the power transformer maybe out on the set.it supplies power to the whole set and it sounds like it only getting partial power.
Jan 17, 2009 | Panasonic PT-52LCX66 Projection Television
SONY GRAND WEGA KDF55WF655
tv turned off black screen and red light flashes 6 times over and over again
Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Mar 21, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Samsung SP50L3HX 50" DLP TV Logo
52 people viewed this question
Henry  Thomas
Henry Thomas
