I have a Dyna Glo RMC-50LPT propane space heater. Can it be converted to natural gas by changing an orifice? What size orifice? What are the dangers of operating a LP heater on natural gas?
  • 43,501 Answers
Yes, you should be able to convert that....
Contact the company directly, the distributor, of the literature that came with the unit for orifice sizing.....AND conversion kit for the regulator....
The danger of running a heater on the wrong gas is that it will produce CO (carbonmonoxide) and you will wake up dead....
heatman101
Posted on Jan 02, 2011
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Pilot flame will not remain lit.
u sound like u have a bad regulator
Feb 18, 2010 | Dyna-Glo RMC-8001SS Heater
I want to connect the unit to the main propane
First of all I am only concerned with your safety when I ask you to only have a qualified service tech install this heater for you. PROPANE is very dangerous if you aren't well trained in the operation/installation of gas fired equipment.Natural gas isn't quite as dangerous as it is lighter than air and will dissipate easier. Propane is heavier than air and will pool in the lowest spaces and collect there. To answer your question, yes most regulator can be adjusted, but again only by a qualified service tech because he needs to adjust the gas pressure to the equipment rated gas pressure specs. Again I am only concerned for your safety.
Nov 28, 2009 | Dyna-Glo RMC-8001SS Heater
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Feb 28, 2009 | Heating & Cooling
Convert from lp to natural gas
you need to go to the manuel and check if you can retrofit the heater to natural gas. there is a difference in the ORIFICE size. or check to see if there is a phone number to the manufacture and talk to them. THE BEST THING FOR YOU TO DO IS TO GET A CERTIFIED A/C PERSON TO DO IT, IT IS VERY DANGEROUS IF YOU GET THE WRONG ORIFICE SIZE !
Jan 05, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Dyna-Glo natural gas space heater to propane gas.
Yes it is possible and a good idea. You need to have a regulator installed to reduce the pressure to the heater and this is a simple procedure. Contact your local Propane distributor and they will probably do this free to get your business.
Ray
Dec 08, 2008 | Dyna-Glo Heating & Cooling
Yes and most larger hardware stores will carry the parts ( it should only be a connector and a small adjustment...cost...maybe $6.00 to do
Shuts off when switched to low and smells when running.
clean the burner and the orifice you can use a air line or blow off a vacum cleaner
Nov 20, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Dyna glo ventless rmc50 ngt
All gas heaters can be converted from one type of gas to another, be it natural or propane. The problem is getting the orifice retrofit parts that fit that particular brand. If the manufacturer doesn't make them, then you are left with no choice.
Mar 12, 2008 | Heating & Cooling
Heating & Cooling Logo
122 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
