My Armstrong model # GUJ100D12-3A just stopped working. The blower seems to work, but cold air just comes out. The Temperature in the house was 41 degrees, but I had the thermostat on 60 degrees. What could the problem be? I thought maybe the pressure switch? Can you help me figure out what is wrong?
  • 2,133 Answers
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Posted on Jan 03, 2011
I have a Armstrong concept 10 central air unit. Everything outside seems to work bit I don't have cold air coming out. Its just basement cool
Its possible you have an airflow issue such as a dirty evaporator coil or dirty blower wheel/fan. Or the blower motor has slowed for some reason. Sometimes the plenum or ductwork is improperly installed or sized an will not create static pressure. That's harder to explain.
Jun 05, 2015 | Heating & Cooling
Air conditioner blower won't run
need too check your orifice tub it could be colgged but make sure you check first your high pressure switch
Jun 18, 2014 | Lennox Armstrong Furnace Control Board...
My A/C is operating outside the house, but there is no cool air inside the house. We set the temperature onto 84 F Degree, however, the inside-house temperature has already reached 88 F Degree. Can you...
With such limited information the following is the most likely problem.
1. The fan outside is running but the compressor is not.
2. The inside air handler blower fan is not working.
3. The system is froze up and not allowing any cold air to come out of the vents.
Hope this helps
Sep 19, 2011 | Honeywell Heating & Cooling
My Honeywell AC unit doesn't seem to be working properly. It will not retain a temperature. I set the thermostat to hold a temperature of 70 degrees. Room temp still reads 74 degrees. Something is working,...
The frost on the pipe indicates you have a dirty filter, dirty evaporator coil, Blower not running at the proper speed (to slow) or you are low on refrigerant.
Jun 29, 2010 | Heating & Cooling
The blower works and a/c works but no heat comes out
If the blower is blowing air just fine, but you cannot control the temperature, you need to listen to air coming from the vents while turning the temperature from hot to cold. If you do n ot hear any change in airflow, then you may a temperature door in the dash broken. this is becoming a common problem on the Equinox
Tech JK
Oct 11, 2009 | 2006 Chevrolet Equinox
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
Honeywell CT3600-AC not working
could be froze up if it is turn it off to melt ice clean unit could be low on freon or bad blower motor
Jun 17, 2009 | Honeywell CT3600 7 Day Electronic...
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Armstrong 4PHP13E36P runs after heating element cools
There may be pins on the circuit board inside the air handler that you can adjust. First turn off the breaker then look inside at the board. They may say 30-45-60-90 etc. Put the pin on a lower number. Do you have a digital or programmable T-stat? There may be a setting in the T-stat setup program that allows for blower delay also. consult you installation instructions. Last if the blower isn't turning off at all then the relay on the circuit board is stuck closed and should be replaced.
Mar 10, 2009 | Heating & Cooling
Heating & Cooling Logo
399 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
