Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
The heating element does not function; it use to. Also, the detergent dispenser door does not open during the wash cycle. So, how do I determine the cause of the problem - burnt out element, bad switch, etc? Are the issues possibly connected, or separate? Thanks in advance!
  • wyatttroxel Jan 02, 2011
    Thanks for the notes; very helpful. I anticipate only 2 problems: (1) getting down on my knees, and (2) getting back up again. Also, thanks for the extra note on routine maintenance; very kind and thoughtful of you.
    Thanks!
  • Whirlpool Master
  • 43,501 Answers
Probably two different problems....
Dishwasher Repair Problem Detergent Cup does not Open
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Posted on Jan 02, 2011
  • D. Floyd Kolb
    D. Floyd Kolb Jan 02, 2011
    LOL... I hear ya about the up and down business....:-)
    If you could accept this and give me a rating It would be appreciated...
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Soap door will not open during washing cycle
Well as controlling cycle times, the timer on many dishwashers also functions as an actuator for the spring-loaded dispenser door. At a certain specific time during the cycle, the timer will activate a lever that in turn opens the detergent cup. If that lever is broken or in some way defective, it will need to be replaced. Alternatively, the timer's motor itself could be the problem. If your timer is not functioning properly, then the dispenser door may not function properly either. Test your dishwasher's timer motor, and if it is broken, you can replace either the entire timer assembly or just the timer motor. Please post the model number of your dishwasher for more help or information.......
Good Luck!!
Thanks
Mar 01, 2010 | Maytag Dishwashers
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Soap dispenser does not open during wash cycle
  • Hi,
    please try this...
    imer:
            On mechanical set ups the timer is attached to the detergent cup by an actuator arm. This arm is usually plastic, and if it is broken or otherwise defective then the detergent cup wont be opened. Check the linkage to make sure it is functioning correctly.
    Bi-metal switch or wax motor:
            The bi-metal switch is simply a very precise device that warps, bends, or otherwise deforms when power is supplied to it. The timer operates the bi-metal switch, which inside the dishwasher door. Then the switch is supplied with power and it is working properly, the bi-metal switch deforms away from the latch holding the detergent cup closed and the cup opens dumping the detergent into the washer.
            Some dishwashers have this switch wired through the motor power feed or the heating element. If they are defective then the detergent door will not operate correctly. If the switch itself is defective then you will need to replace it. Another type of mechanism is a wax motor. Wax motors are sealed units filled with wax and found in newer dishwashers and work by heating the wax and forcing up a piston which in turn mechanically opens the detergent cup door. This type of device is also controlled by the timer.
    Detergent cup:
            Sometimes the detergent cup becomes built up with old detergent that prevents it from opening correctly. It's usually a simple fix to clean this out. If cleaning it is impossible then you may need to replace the cup assembly.
    please rate my suggestion..
Apr 14, 2009 | Dishwashers
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    Bosch diswasher detergent dispenser doesn't open during wash cycl
    I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
    Dec 24, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
    Main Detergent Dispenser does not open during cycle
    check to see if anything like dried up soap in there if so wash out with warm water or try a liquid
    Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
    I had this problem - the dispenser only opens if there are small items in the rack in front which don't come up to the same height.
    Jan 08, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
    Bosch Aquasensor Detergent Dispenser door wont open during cycle
    Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
    Nov 17, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
    Detergent will not dispense during the wash cycle
    Something simple you can check is to make sure the spring that flips open the door is not broken or caked up with detergent.
    As for the soap not dissolving, I've had similar problems and the only solution I've found is to make sure you are not blocking  the spray jet on the bottom from hitting the soap drawer.
    Oct 26, 2007 | Frigidaire 24 in. FDB635RF Built-in...
    Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
    Top Whirlpool Dishwashers Experts
    Mike
    Owen Barnes
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
