Question about Kenmore Refrigerators
Kenmore refrigerator 363.9771612 - the refrigerator operates but when the compressor shuts off, the compressor has an interior rattle as it shuts down. What could be the problem? I looked for a loose bracket, but the noise appears to be coming from inside the compressor.
watugot
  • 290 Answers
SOURCE: Kenmore (253.51399104)side by side making buzzing/humming noise
It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
Thanks/Mike
Posted on Dec 06, 2007
catriver
  • 878 Answers
SOURCE: Kenmore Frig Noise
TD, sounds like your valve springs in the compressor let loose and it's banging on the side when shutting down and equalizing. The compressor has a 5 year warranty. This is more annoying than anything. If it's under warranty, have them replace it. If not, it's up to you whether you want to live with it. Catriver.
Posted on Dec 16, 2007
leorcid
  • 281 Answers
SOURCE: noisy refrigerator compressor (?)
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
Posted on Feb 06, 2008
docjohn174
  • 943 Answers
SOURCE: Kenmore refrigerator not cooling
hi thanks for the question if both fans are working no ice build up & no dirt on condencer by the compressor sorry but you need a new compressor thanks the appliance doc
Posted on Sep 22, 2008
  • 958 Answers
SOURCE: Whirlpool 20.8 Top won't cool neither refrigerator nor freezer
that's about right, if the compressor is drawing more than 4 amperes, then it is no good.
A reminder also to check the condenser for dirt and debris that could have accumulated at the front, this is a major contributor to compressor failure. check also the fan near the compressor. it should be running at the same time the compressor runs.
that's nice to hear from whirlpool....
good luck tapperal,
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
What is wrong with the Kenmore Elite refrigerators they have now? I bought one and it is very noisey. I hear the compressor running from rooms away and it's not a rattling just the noise of it running
If you are wanting to check and see if the compressor is operating and actually working, find the small refrigerant line coming off the compressor and follow it several inches and check its temperature. The normal temperature is over a 100 degrees and should feel very hot. Be careful the normal range is over 140 degrees on most model and may cause burns. If it is hot to the touch, that means the compressor is working. If it is not hot it means you have some problems with the compressor and probably need a new one.
If it is hot, the most common problem with a real hot compressor is a dirty condenser. If your models compressor hot line dissapears into the casing (walls of the refrigerator) then you cannot clean the condensor, but if it goes into a finned condensor with a fan, you need to check if it is dirty and just needs cleaning. This is a very common problem and periodic cleaning needs to be performed. Your refrigerator loses heat removed from the interior by rejecting the heat to the air passing over the condensor. If it can not breath due to dirt buildup, the refrigerator will over heat and lead to prematur breakdown. If the systems has operated long enough at a high temperature, the refrigeration oil in the refrigerant system can decompose and form sludge and block the capillary tubing. Once sludge start forming it is very difficult to flush the sludge out and a compressor change out typically can not fix the system because remaining sludge. In this case it is cheaper to buy a new refrigerator and remember to clean the condenser every year at least, more ofter if you have cats and dogs. They have a tendency to shed and the hair gets into the condenser. I had a customer once that used the air flow to the condenser as a vacuum cleaner because the dirt dissapeared near the air suction, until the condensor clogged up and the refrigerator stopped cooling, go figure.
Hope this helps
Aug 01, 2014 | Kenmore Refrigerators
Why doesn't my Kenmore Refrigerator/Freezer freeze food?
The compressor could be failing, especially if it was running when the power outage occurred.
Jul 15, 2014 | Kenmore Refrigerators
Refrigerator Rattles
Perhaps some of the shipping blocks are still on the compressor or other parts.
Apr 20, 2014 | Kenmore Side by Side Refrigerator
Kenmore model 596 52679200 compressor starter rattles.
It might be on the way out I would get the new relay and have it ready when the box fails. leave it be till it goes on out. But be ready. If it was bad it would either not do nothing or overheat and shut off.
Dec 27, 2013 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Compressor shuts off and makes big rattling sounds
Here is a tip that I wrote about the clunkingor thumping in refrigerators...
Refrigerator Clunkingin back
heatman101
Jul 25, 2011 | Kenmore Refrigerators
The compressor works fine, but when it shuts off after cooling the refrigerator it rattles very loud. Any way to fix it or do I need a new compressor?
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Mar 21, 2010 | Kenmore 57029 Side by Side Refrigerator
Makes a shuddering noise when compressor turns off
It sounds like the suspension spring has broken inside the compressor so when it shuts off it rattles against the case. If the refrigerator is still operating normally I would recommend not repairing it. It could run for years like this without any further problems and a compressor change would be very costly.
Feb 24, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Frig makes a very loud booming noise/ratteling what is the cause?
The noise is coming from the compressor and is a result of a broken support spring inside the compressor. When the unit shuts down, the inner casing rattles against the outer casing because the spring is not there to keep them apart. The only fix is to replace the compressor but otherwise it is just bothersome.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Refrigerator making noise at bottom rear when shutting down.
This sounds like a compressor motor mount problem. Unfortunately, the only way to fix this is to change the entire compressor, which is something that only a trained technician can do- they will need to drain and recharge the freon. It can cause upward of $400 or more. Fortunately, your refrig will still work if you don't mind living with that sound.
Dec 29, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
111 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
