Question about Hitachi 42HDS69 42 in. Plasma Television
42 hds69 has a red light with main power if i hold down the power button goes to a blue light but no dispaly
2 Suggested Answers
pattersj78
  • 70 Answers
SOURCE: no pic hitachi 42 hds69 3 blinking lights on back
http://www.hitachi.ca/supportingdocs/en/forhome/plasma_tvs/42HDS69.pdf
Here is the user manual. You may need to call Hitachi.
Posted on Nov 28, 2008
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
Tip
How to put most Bluetooth headsets into Pairing Mode?
There are two main ways to put your Bluetooth Headset into Pairing/Discovery mode:
1. For devices that have a Power Button
Start with the headset in the OFF state, then hold the power/action button until it goes into pairing mode (about 3-5 seconds). When in pairing mode, the light should be flashing red and blue or have a steady blue light, in most cases.
Then you can discover it with your phone or PC.
2. For device that have an On/Off SWITCH
Start with the headset in the OFF state, then hold the call/action button while you turn the headset ON. The headset should now flashing red and blue or have a steady blue light, in most cases.
If you forgot the pairing code, refer here:
http://www.fixya.com/support/r5008953-pin_codes_most_bluetooth_headsets
If you need a copy of your manual, refer here:
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
on Jun 02, 2010 | Radio Communications
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
42 inch lcd with blinking red light
I just fixed mine, I am not exactly sure what did it, but I held the power button down while pushing and holding each button for a few seconds after going through each button I unplugged power cable and then plugged it back in and it powered it up and it worked
May 21, 2010 | RCA L42WD22 42 in. LCD Television
Where?
power button is the little nipple between the phone and play/pause pictures on right side. You hold down for 2 seconds until blue light comes on to turn on.
Too shut off hold down button 4 until red light comes on.
if want too pair with device hold button down 6 seconds until light blinks blue red
pass code is 0000
May 15, 2009 | Insignia Bluetooth Wireless Headphones...
Headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
May 09, 2009 | Plantronics Discovery 925 Bluetooth...
925 Plantronics will not pair with cell phone.
You are holding down the main button too long.  When it flashes blue and red it is now in pairing mode.  To turn on the headset hold down the main button until you see the blue light come on, then let go.  If you hold it any longer this is when it goes into pairing mode.
Feb 24, 2009 | Plantronics Discovery 925 Bluetooth...
Nec 42'' plasma
Try holding down the 'INPUT SELECT' button, then press the power button on, on the tv at the same time.
Oct 29, 2007 | NEC PlasmaSync 42MP3 42 in. Television
Hitachi 42HDS69 42 in. Plasma Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
