Question about Toshiba 32HL66 32 in. LCD HDTV
How do I remove the base from a 32 inch Toshiba Regza televison that was made in 2007?
ctf1800
  • 4402 Answers
SOURCE: Toshiba Regza 32"
I would return it, sounds like the bulb died.
Posted on Feb 22, 2008
  • 47 Answers
SOURCE: Two DVD's stuck in Toshiba Regza with built-in DVD player
If you can find a piece of stiff wire, put a small 90 degree bend onto one end and try to hook the edge or middle of the DVD drawer and pull out the drawer. It will resist a bit but should come out.
Posted on Jun 25, 2009
SOURCE: Can't remove base-mount from Toshiba REGZA 46
Go to http://www.youtube.com/watch?v=rWAJqNVTqug.
The secret is locating a total of four hex (or in some models - 5) screws located at either side near the bottom at the back of the unit.
Posted on Jul 04, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
  • 8457 Answers
SOURCE: how to set up freeview on toshiba regza 32 inch tv
Make sure set on air,not cable in menu setting,Get a digital antena or a rooof antena.Hook up u should get the DTV free signal.
Posted on Nov 24, 2009
How do i remove swivel base from toshiba regza 42xv540u
Make sure you check the owner's manual. You can probably get a free download if you lost yours.
Some TVs have screws on the backside near the bottom, not just underneath.
Jun 17, 2014 | Toshiba REGZA 42XV540U 42-Inch 1080p 120Hz...
How do you change the time zone on 2007 Toshiba Regza 42HL67?
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Jul 24, 2017 | Toshiba REGZA Televison & Video
I have a 32 inch toshiba regza tv flat screen. How do I remove the base.
thinking its gonna be a 4 hole pattern spaced about 4" and contain phillips screws they are usually found in this pattern on the lower rear center of the set but from time to time they can be located on the underside of the base start with the rear ok :) very easily done i have faith you will do it :)
Feb 18, 2011 | Televison & Video
How do I retune a Toshiba Regza 32AV615DB 32-inch when I select retore defaults nothing happens
what are you trying to do ?
if your trying to re scan your channels then go into youe setuo menu and rescan channels in cable mode if your on cable or antenna select air
Dec 02, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
How to set up freeview on toshiba regza 32 inch tv
Nov 24, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
32 inch lcd tv installing problems
Buy a flat panel bracket.Use a stud finder and bolt to the wall studs
Sep 16, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
Cant get dtv on my toshiba regza
Does it work with a DVD or VCR?
How is it connected? With a Coax cable or a an RCA component cable? Check that the correct video source is selected (The one associated with the input you are connected with) or that you are tuned to the correct channel on the TV if you are using the coaxial cable to connect. Could be channel 3 or 4 but I have seen them set for channels like 73.
Jan 03, 2009 | Televison & Video
Toshiba 32HL66 32 in. LCD HDTV Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
