Question about Bosch Dishwashers
She56c05uc bosch dishwasher won't drain. The drain and hose are not plugged. The dw makes normal sound in drain cycle. Any suggestions on how to test the pump?
silly girl
  • 513 Answers
SOURCE: Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Posted on Mar 26, 2006
  • 213 Answers
SOURCE: Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Posted on Nov 20, 2007
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
  • 205 Answers
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Posted on Jul 21, 2009
  • 457 Answers
SOURCE: water wont drain, I have removed drain hose from
im a old bosch tech and your problemis in the drain pump. remove 1 screw in the bottom of the unit and you will take off the plastic door, spin propeller and remove obstruction that will do it. if this helps send me a 4 thumbs up post thanks
Posted on Mar 01, 2010
Bosch dishwaser. starts and stops, it will say clean. leaves water in the bottom. we purchased a new pump and still not working? :( :(
All dishwashers leave a little water in the bottom. However, I suspect there's an appreciable amount in the machine. I'd suggest you lift out the filter and check the drain port.
Feb 11, 2015 | Bosch Dishwashers
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
DW just installed. Water doesn't drain when cycle is finished.
is this brand new ? if so check where the D/W drains...it should drain into sink through disposal or sink drain adapter ..was the plug removed from the disposal ?for the dishwasher to drain ?remove drain hose from disposal or sink adapter.put in bucket turn on to see if it drains ..if so remove the plug from disposal or clear debri from hose or disposal /drain adapter..let me know..good luck/joe/
Aug 28, 2010 | Bosch Evolution 800 SHE58C05UC Stainless...
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Bosch dishwasher stinks/smells
a product called dw magic will help get the smell out then after that leave the door cracked open so the moisture can exit the machine
Sep 03, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Water won't go out of the dishwasher
Begin at your sink drain that the dishwasher drain hose connects to. Disconnect the hose and check both directions for anything plugging the connection.
Make sure the drain hose has not become "kinked"
(After you have emptied the water from the dishwasher) remove the lower spray arm and the filter in the sump area. Look for obstructions and remove all debris. Rinse the filter thoroughly and reassemble.
If you dishwasher has a timer on the front of the dishwasher that you can manually turn, start a quick cycle with no DW soap and empty.
Allow the water to run in for several seconds and then manually (slowly, gently) turn the timer knob until the DW should begin draining the DW. Listen closely for the sound of the pump motor running.Is water properly draining out of the dishwasher into the drain?
After you have done these things, please post back here and we can take the next steps. OK?
Apr 09, 2009 | Dishwashers
Our Bosch diswasher smells (foul odor) after a wash cycle.
Make sure the drainage hose is not pushed all the way through the gooseneck in the pipe. Doing so will bypass the standing water which prevents sewer gasses from escaping into the dishwasher.
Dec 28, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
MY DISHWASHER IS NOT DRAINING. I REMOVED THE DRAIN IT DOESNT SEEM TO BE CLOGGED .
When you say that you removed the drain, are you talking about the filter screen and you removed all sediment from previous wash cycles? If so, does your dishwasher drain into and thru a garbage disposal in under your sink? Sometimes that gets clogged and when the DW tries to drain thru that, it just builds up and doesn't empty the DW properly. A quick yet not so painfree check can be to detach the dishwasher drain hose from wherever it is clamped on ( under the sink ) and run the dishwasher thru a cycle //but allow it to drain into a good sized bucket.. If that works OK and you have a good flow .. then chances are your drain system is restricting it from draining.. Conversely, if the DW drains very slowly then there is a good chance your pump, the line into or out of the pump may be clogged or the pump itself is malfunctioning.. Those are the main components to look at..Hoe that helps you !
Aug 19, 2008 | Bosch Dishwashers
I have new Bosch dishwasher..lassic electronic....the check water level keeps coming on because water is not pumping out....tried to reset and it still willnot pump out....any suggestions
check the drain connection.....if it is connected to a garbage disposal make sure the drain plug knock out is removed otherwise the dw will not drain. Also make sure the drain hose is not pinched or kinked.
Aug 02, 2008 | Dishwashers
Bosch SHX46A dishwasher
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Apr 01, 2008 | Bosch 24 in. SHE56C05UC Stainless Steel...
Dishwashers Logo
66 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
