Question about Acer Aspire 3680 Laptop
Headphone jack Could you tell me how to go about setting the headphones as the default speakers? I can't figure out how to do it.
    Scholar:
  • 81 Answers
Goto your computer's control panel, and then click on your sound icon. When your sound properties come up, You should see your playback properties. It will have three options at the top (playback, recording, Sounds). Make sure your playback is clicked. You should see Speakers/Headphones, and next to it, you should see the source of playback sound your system is playing through. You should also see your headphones/headset listed. At the bottm, you should set your headset/headphones as the default source that you want to hear your computer audio play through. Once you click that, close it all out, and then make sure whatever you are trying to listen to is closed and then reopened. Once you do that and then reopen the item that you want to listen to, you should hear it playing through you headphones/headset. Thanks
Posted on Aug 27, 2008
  • 476 Answers
When the sound device is installed it should give you sound effect manager or sound device,to access this go to START then CONTROL PANEL then SOUND SPEECH AND AUDIO DEVICE,open Sound Effect Manager,then Sound Effect,select Headphones from the Enviroment Dropdown and click ok.test this output now.
If this doesn't resolve the problem ,
reinstall device again.
Posted on Jul 13, 2008
2 Suggested Answers
  • 8909 Answers
SOURCE: Initially the main speakers would not shut off
If you right hand mouse click on the louspeaker icon, click on open volume mixer.
You can set the headphone volume and speaker volumes from there. (depending on your OS and set up preferences)
Posted on Nov 17, 2010
Acer iconia tablet problem
Few things.
If you are talking about the built in speakers, make sure your volume is turned up. And make sure its turned up when the headphones are not plugged in. My android tablet has individual sound profiles so while I might have the sound muted when the headphones are not plugged in, if I plug them in, the volume jumps to my set level because that's where I turned the volume up to last time the headphones were plugged in. I've also had two tablets that the speakers went out completely on that to is a possibility but if you are talking about the built in speakers, check the volume levels first. You can get to them in the settings menu. Its worth noting that plugging anything into the headphone jack will "turn off" the internal speakers altogether.
If you are talking about external, plug into the jack speakers, on a tablet, you're going to need a set of powered speakers as that jack is not going to produce enough power to drive an un-amplified speaker. Make sure you are using a pair of speaks that plug into the wall such as PC speakers.
Second, if you are using powered speakers and still not getting any where, look at the jack end of your head phones and compare it to the jack end of your speakers. I know iPhones and other Apple devices have an extra connect which is why the Apple head phones all have an extra ring. My older headphones are worthless in my iPhone because they lack said extra connection. It's possible your tablet also requires the newer connection and the headphones have that while your speakers don't.
Broad answers, but I couldn't tell exactly what we were looking at based on the questions. Hope it helps, and good luck!
Apr 22, 2014 | Computers & Internet
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
Headphones for a laptop not working
The Laptop has 3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
hope this helps
Sep 02, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
Initially the main speakers would not shut off when the headphones were plugged into the headphone jack. I reset the audio settings to the factory default. Now the headphone jack does not work. How do I...
Nov 17, 2010 | Toshiba Tecra 8100 Notebook
Using headphones
You can get a set of speakers that has a headphone jack on front (it will shut off the speakers when headphones are in) or you can unplug the speakers and plug in the head phones. Some PCs have a red and green jack in front - plug in headphones to the green, you should have the speakers shut off till you unplug. All else fails they make a headphone/mic extender that sits like a hockey puck on the desk, has cables to the mic and speaker jacks on back of the PC and on the puck part has a jack for speakers, mic and headphone - some switched manually by you, some switch when the headphones plug in. If you had posted the model I could see if your machine has front red and green jacks.
Jun 19, 2010 | E-Machines eMachines Desktop PC
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Acer laptop no sound in headphone jack
I have an Acer Aspire 7720z and have had the same problem. I am assuming your OS is Vista.
Go to Control Panel -open "Sounds" folder and you should see "Headphones" in the list under "Speakers". There will be a green tick on the "Speakers" symbol. Right click on the headphones symbol and then click "Set as Default device". Click OK and the headphone socket should now work correctly. It sorted my problem. If you want to go back to using the crappy internal speakers follow the same procedure setting the speakers as your default device.
Enjoy.
Jan 08, 2009 | Computers & Internet
Fujitsu T series; no sound when I plug in the headphones
I have the same problem and just figured it out. Go to the sound settings and set the earphones as the default. I just did this and it now works.
Nov 27, 2008 | Fujitsu LIFEBOOK T4010 Tablet PC
Acer Aspire 3680 Laptop Logo
193 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
