Master
- Posted on Jan 02, 2011
Re: Console not responding. have changed remote and...
This information comes directly from Nintendo's website. Hope this can be of help:
First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote:
- Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info).
- Make sure you are using fresh batteries in the Wii Remote.
- The Wii Remote Controller should be used between 3 to 10 feet from the TV.
- Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
- Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
- Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
Verify Sensitivity Setting dots:
Go to the Sensor Bar's sensitivity setting in the Wii menu.
- If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar.
- If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
Testimonial: "Thanks for the info"
