Question about Dell Dimension 3000 PC Desktop
I was just given a Dell Dimension 3000 by my daughter, who said there was no problems with it. It has a CD-Rom drive and a DVD-RW drive. When I power it up and click on MyComputer, neither of these drives are shown. When I put a CD in the drive, it closes normally and will eject normally, however there is no communication with the operating system (Windows XP). When I click on Control Panel, then System, then Device Manager, it shows the drives. Then when I right click on a drive, then click on Properties, it gives a Device status message "cannot load the device driver for this hardware. The driver may be corrupted or missing. Code 39". It does this for both drives. I find it hard to believe that both drives are bad. What am I doing wrong?
  • Jeffrey Groves
    Jeffrey Groves Jan 02, 2011
    Have you inspected the "Master/Slave" jumper settings on the drives and verified that they show-up in the BIOS/CMOS settings? That's where I would start.
    Brigadier General:
  • 8,909 Answers
They probably can't load because they are loading at the same time and XP can't sort it out.
Remove the cable from the CD ROM and re boot but enter the BIOS and make sure it is no loonger there.
The nachine should load the DVD rom.
You can try adding the CD rom now, it may work but being XP it may grab the wrong driver again and hang up.
Download new drivers from Dell.com
Hope this helps.
Posted on Jan 02, 2011
What do I set my CD-Rom Jumpers to in a Dimension 1100
Which is it a Dell 3000 or Dell 1100 ?
The jumper settings on the rear of the DVD drive; set the jumpers to "cable select" mode (if you are uncertain how to set the jumpers, check the documentation that came with your drive or look for a diagram printed on the drive itself). Insert your DVD drive into the selected drive bay and connect the IDE and power cables. Use the screws that came packaged with the drive to secure the component to the drive bay.
Dell Dimension 3000 Service Manual
http://support.dell.com/support/edocs/systems/dim3000/en/SM/sm.EXE Dell Dimension 3000 Users Guide http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
I have a dell dimension 8400 with a TSST CORP TSH492B cd-rw/dvd drive. Windows only sees this as a cd-rom and automatically uses the following drivers storprop.dll cdrom.sys imapi.sys redbook.sys. I...
those are the basic drivers for all cd. dvd, and rw drives. if you are trying to use the drive to burn a cd/dvd you need to purchase software for it your download a free burning software from filehippo.com called xpburner or burnerxp i cant recall the exact name
Apr 14, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
Need to replace cd-rom drive, how difficult? dell dimension 3000 pc desktop
It is not difficult to change cd/dvd drive.
Open cpu cabinet.
Then remove icd cable and power cable from cd/dvd drive.
Then remove screws of old cd/dvd drive.
Then you can pull it from cabinet from front side.
Then put your new cd/dvd drive into it's position then lock it with screws.
Then connect ide cable from motherboard and power cable to drive.
Then you can use it.
If you connect to drive with 1 ide cable means if you connect harddrive and cd/dvd drive with 1 cable then set harddrive as master and cd/dvd rom as slave you can set it slave with jumper settings.
It is in back side of cd/dvd drive.
There is instruction how to slave it with jumper.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 17, 2010 | Dell Dimension 3000 PC Desktop
Grinding noise from the disk drive
there a defective cd/dvd drive, try to change-it.
Jan 02, 2010 | Dell Dimension 3000® Pentium® 4...
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
Phillips dvd-rw dvr 111d in dell dimension 3000 not recognise as dvd rom drive, that is play cd but not dvd
Close all the burning softwares and check if its working, if not try to flash the chipset for the drive, this would be very much available in the support site, u can download and run the same in the system.
Jul 30, 2009 | Dell DVD-rom DVD Drive
Replacing a cd drive
The 4600 has PowerDVD to play DVDs (You should have the software CD to install it on the 3000) DVD burning software would be Roxio/Sonic, and you should have that CD too.
If you don't have the CDs, then try download.com to download Free player software and Burning software
May 25, 2009 | Dell Dimension 3000 PC Desktop
DVD drive help for Dell Dimension 3000
call DELL support and explain to them, they have send your the wrong type, what you have is IDE, they have send you the ATA. which the motherboard can connect.
Jan 09, 2009 | Dell Dimension 3000 PC Desktop
CD/DVD-RW Drive
Any DVD Read writer will work
Jan 01, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
Alun Cox
