Question about Samsung YP-U3 MP3 Player
I have the same problem
I have the same player and i had the same problem, when i connect to pc it keep on charging and did not recognized by pc. did you fix it please tell me how you fix it.. many thanks.
Please send me a mail
pubudu_bandara@yahoo.com
5 Suggested Answers
SOURCE:
jdiz53
  • 12 Answers
SOURCE: natia_zamtaradze@yahoo.com
you can try to run the new hardwhere wizard in control panel. if not you can visit the manufacturer wabsite to get drivers and other downloads
Posted on Jan 17, 2008
SOURCE: mp3 player from Samsung YP-U3JQB/XAA not recognized by my pc
Very helpful the Best Solution...thanks.
I've been trying for over a week to solve the problem with this YP-U3 and was about to return it and than I tried this and it worked....
Posted on Apr 03, 2008
webmaster21
  • 803 Answers
SOURCE: yp u3 cannot be detected by computer
Download the driver from the Samsung Support Page and force download the driver with the steps below:
1. Look for the icon named "Computer" or "My Computer" and right click on it and select properties, this will open a window named "System Properties".
2. In the system properties windows click on the tab named "Hardware", and Select "Device Manager".
3. On this window you will see all the devices installed on your computer, look for the device not working properly (printer, dvd rom, keyboard, camera, mp3 player, etc), if there is a bigger problem, more likely you will see a cross by it, or an alert stating there is an issue with it.
4. Right click on the device you where having problems with and select uninstall, it will give you a confirmation, press OK
5. Once the device disappeared from the list, click on the menu bar icon that looks like a computer with a magnifying glass this will cause for the system to scan for any devices not registered and will force the re installation of the device.
Posted on Oct 05, 2009
  • 12 Answers
SOURCE: I/O Error on my samsung YP-U2 digital audio player
hi :
your player iz need to a current updater progrrame by picking the firmware version of samsung site...and install to pc after then connect he player in usb dvice and re install the firmware....
Posted on Feb 18, 2010
It wont connect with my computer
Search Results
    My laptop does not recognize my mp3 player [Solved] - CCM
    ccm.net > Forum > Hardware > Laptop
    Jan 18, 2013 - Connect the player, open device manager, right-click on WALKMAN under .... my sony mp3 walkman,my computer dont recognize it,i cant upload my .....Does not charge. is not recognized by windows media or My Computer. My computer does not recognize my mp3 player.
    Nov 16, 2014
    I cant get my songs to my mp3 player
    Oct 11, 2013
    Sony Mp3 Walkman is not getting Detected !
    Oct 31, 2012
    More results from ccm.net
    My PC does not recognize my MP3 player - CCM
Jan 06, 2016 | Audio Players & Recorders
My coby mp touch isnt connecting to my pc
Turn on MP3 player
Go to Setup > System > USB MODE
Put the USB MODE to MSC
Reconnect to the computer
Your computer should then recognize the MP3 player.
Apr 12, 2010 | Coby MP-705 Digital Media Player
My sharper image MP3 isnt charging.
Make sure the firmware is up to date
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jul 05, 2008 | Audio Players & Recorders
Samsung YP-K5JAB
Wizard
Jun 10, 2008 | Samsung YP-K5JAB MP3 Player
Can Charge but not connect
i can't put my music from the computer into my mp3
May 05, 2008 | SanDisk Sansa Clip MP3 Player
Computer does not recognize device
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 19, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Infitek mp3
Mar 31, 2008 | iLO (2 GB) MP3 Player
Vision M not recognized
I'm having the exact same problem. My zen is 'charging' but isn't detected anywhere on my pc and I'd leave it charging for days but nothing happens. I've tried different usb ports, reinstalling the software several times but nothing. I recently reinstalled Windows and with my new pc my Zen cannot work on it for some reason?! I put previous files from my old pc onto my Zen hoping that I could transfer them onto my new Windows pc but I fear I've lost the data on my Zen completely. Arggh, any suggestions guys? Please..x
Feb 29, 2008 | Creative Labs Zen Touch MP3 Player
Computer does not recognize player when connected
i had the same problem with my c240..my computer would not recognize that i had connected anything..so i went to settings on the player scrolled down to USB option press ok and changed the setting to MSC instead of auto detect ..i reconnected it and the player came up immediately ..worked for me hope it does for the rest of you..{if anyone knows how to delete songs let me know..thks}
Nov 10, 2007 | SanDisk Sansa c240 MP3 Player
How Do I Charge my Sans Mp3 Player
Make sure you ran the install CD first
Sep 30, 2007 | iLO (2 GB) MP3 Player
Samsung YP-U3 MP3 Player Logo
66 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
