A plug melted while we were running a heater - Heating & Cooling
    Novelist:
  • 185 Answers
HI, I am assuming that the cord end on the heater is what melted in use. This happens because the male ends can be dirty or not making good contact with the receptacle. The metal is not making as good contact as it should and the heater current is being drawn through a smaller amount of the metal on the plug. This causes heating, and this then builds and more heating, and so on. I would suggest that you change out the male cord end with a new one.
Posted on Jan 04, 2011
  • 2,133 Answers
1. Undersized plug. 2. May be heater runs with high current. 3. Loose wiring in plug.
Posted on Jan 03, 2011
GE GSH25GGCBBB COND FAN NOT RUNNING, COMPRESSOR NOT RUNNING
If the heater HAS shorted (burned look) it CAN destroy this board. FYI: Usually, heaters burn because the defrost termination thermostat is defective. The heater can literally melt the aluminum shield if this is the case.
ALSO: If your compressor won't run after replacing the heater and thermostat, WAIT for about an hour (with your fridge plugged in) before deciding this board is bad and preventing the compressor from coming on. Mine miraculously started...after 1.5 hours. YES.
It has a pair of freezer sensors (along with the simple defrost termination thermostat) with a microprocessor control that apparently brain fades sometimes.$$ saved.
Oct 15, 2013 | General Electric GSH25JGDBB: ENERSTAR 25.3...
I have a Dimplex CS1205. Plug hot and melted outlet cover.
Many people think melting plugs and outlets are caused by the appliance that is plugged into them. It is very likly that the outlet is worn or loose or wiring connections are loose or the receptical is faulty. Arcing is a major cause for this condition and all of the above issues can cause arcing. This condition usually only happens when high draw appliances are plugged into the outlet. So a lamp could work fine in the outlet for 10 years then a toaster or heater is plugged in and a loose connection causes current to jump from the receptical to the plug prong which inturn causes tremendous heat.
Jan 11, 2010 | Dimplex Compact Electric Flame Stove...
My Heater Blower motor stopped working on my 2007 Chevy Suburban
you will need to check 3 places for this. 1 check the plug going to the blower motor for being hot and melting.2 check the plug going to the blower motor resistor for being hot and melting. 3 check behind the heater control head itself for being hot or melting.chevrolets are bad about these three places not making good contact and melting the connectors.
Dec 27, 2009 | Chevrolet Suburban 1500 Cars & Trucks
My refrigerator is not defrosting. I see ice forming on the bottom of the freezer
what is the model number?try advancing the timer with a screw driver,turn it until it clicks,if the refridge shuts down and goes into defrost you have a bad timer,also when you open the freezer door do you hear the fan blowing,if not you have a bad evap fan motor,melt out the ice and remove back wall of freezer,if you can see the heater and it's on after you advanced the timer that would let you know the timer is bad.if the heater isn't on you'll have to read out the t-stat and the heater to see what part is bad,on some of the models the t-stat has plug in wires on them,you can unplug the t-stat and bypass it by plugging the wire dirrectly to the heater,if the heater comes on you have a bad t-stat,after you find out what part is bad melt out all the ice,if the heater comes on for you leave it on to help you melt it out,make sure you shut off the control in freezer before you read out the parts or unplug refridge until you find out what part is bad,you don't want the machine running while you have the doors open or you can freeze up the air ducts and you'll have another problem
Nov 07, 2009 | Kenmore Refrigerators
Getting this error code on 8550 Phaser: 37,006,42:26076 Have been having problems with the fan
Hi outonalimbwi:
Here is your problem.
37,006.42: PEST - Drum disconnect. The drum heater is not drawing the expected power from the supply.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Run the appropriate diagnostic test:
37,002.47 = Left Jetstack Heater
37,003.48
= Right Jetstack Heater
37,004.40
, 37,005.41 = Reservoir Heaters
37,006.42
= Drum Heater
37,008.44
= Preheat Heater
37,009.45
= (8500/8550) All ink melters
= (8400) Ink Melt 1
37,010.46
= (8500/8550) Ink Melt 1
= (8400) Ink Melt 2
37,011.47
= (8500/8550)Ink Melt 2
= (8400) Ink Melt 3
37,012.48
= (8500/8550)Ink Melt 3
= (8400) Ink Melt 4
37,013.48
= (8500/8550)Ink Melt 4
2.
Did the test pass?
Go to Step 3. Go to Step 2.
2 1. Check the wiring running from the component to the printhead.
2. Is the wiring damaged or not working properly?
Replace the wiring harness.
Replace in the following order:
■ Drum assembly
■ Preheater
■ Printhead
■ Ink loader
Aug 11, 2009 | Xerox Phaser 8500N Printer
Water freezes in the drain of the freezer compartment thereby plugging up the drain......with water running onto the floor. I am now running an electric heater in the freezer box to melt the ice &...
There are drain heaters that you can buy that will take the heat off of the motor and transfer it to the tube to keep it from freezing. I recommend buying one, they are fairly cheap. Just call up the local dealer or you can find them on online stores that sell refrigerator parts.
Benjamin
Jul 06, 2009 | Refrigerators
On the DS2205 the electric plug looks like it was starting to melt. Also can I get manual for it?
do not replace plug if you are melting plug then you are putting a band aid where you need stiches,you have a over heating problem with that heater or outlet which could lead to a fire call a pro or stop using heater
Feb 22, 2009 | Dimplex Heating & Cooling
The heater plug melted
Induction coil heaters draw very high amperage (12-14 amps) when turned on. If your outlet is worn or old the heater plug prongs will not have a good connection and the current will jump or arc from the outlet to the heater plug prongs. This arcing causes tremendous heat, enough to melt the outlet and the cord end. First thing to do is change the outlet.
Jan 31, 2009 | Dimplex Compact Electric Flame Stove...
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
