Question about IBM Computers & Internet
I have Ubuntu 10.10 installed on my IBM R40 laptop computer. Although I installed two 512 MB PC2100 266 Mhz memory to both slots. However the computer only sees 512 MB. When I installed Ubuntu I perhaps inadvertently deleted the partition that contains the application to run Access IBM. Is this a software (Access IBM) or a hardware issue?
  • Jeffrey Groves
    Jeffrey Groves Jan 02, 2011
    Is "Access IBM" the BIOS/CMOS configuration utility?
    Brigadier General:
  • 8,909 Answers
Well, what a mine field!
I found this;
There are at least 9 different R40 Thinkpad models. Look for a label underneath & see if there's a "Type" number...something like 2681, 2682, etc. Once you find the number, go to the following site & select your model/type from the dropdown menu:
http://www.crucial.com/store/listmodel.asp?cat=RAM&mfr=IBM&productline=ThinkPad&submit=Go
And being a 256Mb standard, that may be all it can handle. The above link is rather old but worth a try.
Hope this helps.
Posted on Jan 02, 2011
Testimonial: "Quick response. Although not quite the response I was looking for it was because I didn't provide enough information, not the responder."
    Guru:
  • 1,705 Answers
Is Ubuntu installed as a dual boot option.
If so, boot with windows RMB on my computer and select properties. If it gives a reading of 512mb or there abouts, 1 stick is dead, faulty, not inserted properly or the wrong kind of ram.
If running Ubuntu only, click on "Sytem" at the top of the desktop, select "Administration", Select "System Monitor", finally choose the "System" tab. Under the subheading "hardware" you can see how much RAM is running, if 512mb 1 stick is dead, faulty, not inserted properly or the wrong kind of ram.
For the correct type of ram go to the ORCA or CRUCIAL website. Enter your PC details and they'll tell you how much max and what type of ram to install. You don't need to buy from these, but the info is handy.
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Fitting RAM
Here are some instructions that should work for all 3000 series laptops.
http://support.gateway.com/s/Manuals/Mobile/8512061_Apache_RPL.pdf
Mar 31, 2010 | Computers & Internet
Good memory modules put into second slot are not detected in T-30. The second 512 MB module does not show up in the BIOS setup or in Windows XP.
Hello my friend,did you make sure that the ram you installed is DDR SDRAM/Non-ECC/266.0 MHz and that you did put more that 1GB RAM that is the maximum amount your motherboard can take?
Feb 03, 2010 | IBM ThinkPad T30 2366 Notebook
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
Does my inspiron b130 laptop support s video output to my tv?
No. INSB130 does not support S-Video. Here's the complete specs of your system:
Processor type Intel® Pentium® M and Celeron® M
External bus frequency (front side bus) 400 MHz or 533 MHz
System chipset Intel 910GML Alviso
Data bus width 64 bits DRAM bus width Dual-channel (2) 64-bit busses Flash EPROM 512 KB Graphics bus Internal PCI bus 32 bits ExpressCard controller ICH6M ExpressCard connector One ExpressCard slot 54 mm Cards supported ExpressCard/34 (34 mm)
Expresscard/54 (54 mm)
1.5v and 3.3v Memory module connectors Two user-accessible SODIMM connectors Memory module capacities 256 MB, 512 MB, and 1 GB each Memory type 2.8-V SODIMM DDR-2 Minimum memory 256 MB Maximum memory 2048 MB Ports and Connectors :
Audio Microphone connector, stereo headphones/speakers connector
Mini PCI Type IIIA Mini PCI card slot
Modem RJ-11 port
Network adapter RJ-45 port
USB Three 4-pin USB 2.0-compliant connectors
Video 15-hole connector
Network adapter 10/100 Ethernet LAN on system board Wireless Internal Mini PCI Wi-Fi® wireless technology support
Video Type Integrated on system board
Video controller Intel Integrated Graphics Media Accelerator 900
Video memory Up to 64 MB of shared memory (when less than 512 MB system memory is installed)
Up to 128 MB of shared memory (when more than 512 MB system memory is installed)
If this is helpful, please rate it.
Dec 05, 2008 | Dell Inspiron B130 Notebook
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Zlatko
Your laptop can have up to 1 GB of memory. You should have two slots and you can install 512 MB per slot. Your laptop is using 200 Pin DDR PC2100 266 MHz CL 2.5 SODIMM. You can also install PC3200, but your laptop will clock it down to 266 MHz.
Regards,
Feb 27, 2008 | ASUS A2H (A2HOB) Barebone
Computers & Internet Logo
275 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
