Question about Sanyo Televison & Video
Hi,i have a sanyo lcd tv (ce37fd90-b) one of my little darlings has been playing with the remote and turned it off.stand-by light used to flash every couple of seconds now it flashes constantly.am unable to turn tv on at all now for the third day running.unplugged tv from mains/new batteries in remote/left unplugged for hours but no joy just a sodding flashing blue light.HEEEELP Please.Thank you.
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
  • 718 Answers
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
SOURCE: TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
Posted on Feb 23, 2009
SOURCE: tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Posted on Mar 24, 2009
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Code for remote tv sanyo
The code is 049 for my Sanyo TV
With my universal remote you hit the code search key until it lights up then you press and release the tv key
Then enter the three digit code and the indicator light turns off if you enter the wrong code the light will flash rapidly.
Aim the remote at your tv and press the on/off key. If your tv turns off you have found the right code.
Jan 10, 2015 | Sanyo 42 in. LCD TV
How to program this remote.
Hey mate is there a set button on your remote? or similar type of command, if so, turn the tv on by its main on/off button on the tv itself then stand back and point the remote at the tv, now press the SET button down for a few seconds, if you see a flashing light on your remote this means it is searching for a IR signal, cool now just keep pressing the on/off button on the remote say every 2 seconds, as soon as your TV turns OFF press the SET button on your remote and hopefully it should be tuned in and you can use the remote to turn your TV back on and play with menu and stuff. If this worked dude you can join my... getting a remote to work easy club .
May 23, 2013 | Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I need the code to my sanyo tv
Hello
According ro RCA Codes for sanyo are detailed as
Code 004 for sanyo tv Code 048 for Sanyo TV Code 049 for Sanyo TV Code 073 for Sanyo TV Code 080 for Sanyo TV Code 107 for Sanyo TV Code 162 for Sanyo TV Code 169 for Sanyo TV Code 180 for Sanyo TV Code 196 for Sanyo TV
Just check with these codes according to the proceedings.
1. Manually turn on the TV.
2. Locate the enclosed TV Code List. Find
your brand of TV.
Note: If your brand is not listed, use one
of the Code Search methods to program
this remote control. (See section on
Code Search.)
3. Press and hold the CODE SEARCH key
until the indicator light illuminates.
Then release the CODE SEARCH key.
4. Press and release the TV key. The indicator
light blinks and then remains lit.
5. Use the number keys to enter the first
code listed for your brand. After you
enter a valid three-digit code, the
indicator light turns off.
Note: If you enter an invalid code, the
LED flashes rapidly for two seconds.
Start over at step 3.
6. Aim the remote at your TV and press
the ON•OFF key. If your TV turns off,
you have found the correct code.
7. Enter the code in the box provided on
this page for future reference.
8. If your TV doesn't turn off, repeat steps
3-6 above, entering the next code for
your brand.
Manual Code Search
1. Manually turn on the component you
want the remote to operate.
2. Press and hold the CODE SEARCH key
3. Press and release the component key
that corresponds to the component you
want the remote to operate (TV, VCR,
DVD, DBS•SAT, CABLE, AUDIO). The
indicator light blinks once and then
remains lit.
4. Aim the remote at the component. Press
the ON•OFF key continuously until the
component turns off.
Important: Because there are so many
codes, you may have to press the
ON•OFF key many times-possibly up
to 200 times.
5. When the component turns off, press
the ENTER key to store the code.
6. Use the Code Retrieval section on the
next page to identify the code for your
component for future reference.
OK
Feb 15, 2011 | RCA RCU600M Remote Control
My sanyo tv stand by light keeps flashing and it wont turn on can you tell me whats up with it
i have 32inch sanyo tv i have blue light on front whitch comes on when on stand by it wount come of standby eney idears on how mutch it will cost to get fixed x
Nov 13, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
My sanyo L.C.D tv has a constant flashing red stand by light and will not come on
most likly the main power board has failed will need to be replaced
Sep 16, 2010 | Sanyo DP37647 37 in. LCD TV
Whad code do i hse to control my sanyo dp19649 tv
Hi! I will be more than glad to assist you in this concern. this are the tv codes for sanyo. 542, 589, 590, 591, 592,
609. this is how to reprogram you remote to the sanyo tv. you need to press and hold the tv button that is on the upper portion of the remote, on the right side of the sat button. wait until all mode lights lit up, once all lights lit up, release it and then press number ex.. 542 then followed by the pound button, then you will see that the pound button will flash 3 times, it means that the code is program to the remote. note: while your doing the reprogramming of the remote you need to be in front of the tv about 2 to 3 feet away and the tv should be on.. granting u try all the code and none of them works.. try to scan the code of the tv by pressing and hold the tv button wait until all mode light lit up, then press 500 then pound, tv button will flash 3 times, lets say the last code is 500 and it did not work, press again the tv button and wait until all mode lights up, press on the re tv button if you have, but just incase u have only 1 red button for the power, press it once, then press the up button every 1 sec for 5mins. once the tv turn off then press the pound button and the tv button will flash 3 times, it means that you got the code for the sanyo tv, to check the code: Press the POUND (#) button twice. The mode button
flashes the number for each digit of the device code, with a pause between the groups of flashes. A quick flash is for zero. For example, if the code is 570, the mode button flashes five times, pauses, flashes seven times, pauses, and flashes once quickly... lets say that this remote works before with the sanyo and suddenly it quit working , pls call 1-800-333-3474 and ask for the replacement for the dishnetwork remote, remote is bad. please feel free to get in touch if you have any query..
Sep 07, 2009 | Televison & Video
Televison & Video Logo
158 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
