Question about Kohler Tanager K-6491-2R-7 Black Self-Rimming Kitchen Sink
I want to install a soap dispensor. Underneath the Kohler Model K-6491-2R-7 on the right side there is a stensil of a hole and a large phillip head screw in the middle. how can i cut this out to put in a soap dispensor with out damaging the sink
  • 83 Answers
There should be a wing nut under that phillips head screw just unscrew
Posted on Jan 02, 2011
How do I open the soap dispensor for the Brighton Proffesional hands free?
pull it open from the top... squeeze the top sides of the lighter part and pull it down like a drawbridge. If they installed it correctly, it wont rip off the wall.
May 27, 2014 | GoJo GO-JO INDUSTRIES NXT Lotion Soap...
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
I have an AEG 72640. It is taking the fabric conditioner in the 2nd rinse instead of the last and the clothes are not coming out smelling of fabric conditioner. How can I solve this?
Hi. The problem will be one or more of the holes in the top of the soap dispensor (view with drawer out) will be partially blocked causing water to squirt into to one side and fill softener compartment. Dont overfill with softener stay below max level. Holes are not easy to unblock use large paper clip ,bent to allow you to poke holes clear.
Jun 21, 2012 | AEG Lavamat 72640 Front Load Washer
BELT INSTALLATION
the way you install the belt is different depending on the model - the most common kind is whirlpool and kenmore. to install the belt on them you must first pull out the dryer filter on top and then unscrew using a phillip head screwdriver, the two screws on top underneath it. then with a flat head screw driver pop the front up off the dryer. Next you must unscrew the two front inside corner screws using a 1/4 or 5/16 and unsnap the right side lid switch wires. lift up and out to take the front of the dryer loose. now you can put the new belt around the tub and loop it around the bottom belt guide to the moter. Follow the steps in reverse to put everything back together.
Jul 16, 2011 | Dryers
My lever on my single handle kohler shower faucet is very, very loose. How do I tighten the lever. I don't see any screws or place for an allen wrench
There should be a screw hidden under a cap. depending on the model/style it may be as small around as a pencil diameter or as large as a half dollar (the larger is most common on acrylic handles) Just gently pry this off and you should find a phillips screw underneath.
Feb 04, 2011 | Home
How do i get the ignition switch off my 1997 vw golf i took off the safety boly steering wheel and all plug conectors just left with shaft and spring
This is a how-to from VWVortex.com
You WILL need the following,
10MM wrench
13MM wrench and socket or another wrench.
a eyeglasses phillips head screwdriver. (very small)
a regular size phillips head screwdriver
new ignition switch
vice grips (may not need them)
Instructions.
1. lock the steering wheel, and make note where it was just incase.
2. disconnect the battery with 10mm wrench.
3. remove the plastic around/behind the steering wheel by the two screws underneath using a phillips head screw driver.
4. now go under the dash, and remove the plastic peices covering up the steering wheel axel. and unscrew the bolt using a 13MM wrench&socket. Its a "U" joint.
5. Unplug everything behind the wheel including the ignition and the airbag.
6. using a vice grip, or your fingers if it is loose, to unscrew a gold bolt on the left side of the steering wheel column, its right behind the steering wheel on left underside.
7. Gently pull out the steering wheel, and the whole thing, including the axel, and steering wheel will comeout, be careful the end of it is greasy.
8. now with a small screwdriver (phillips), eyeglasses size is what i used, remove the screw where the ignition switch is, its a pretty long screw so it may take some time and it the switch wont come out until its fully unscrewed.
9. replace everything opposite of how it was took out.
Note- when your putting the steering wheel axel back, be sure to put back the large spring and align the axel correctly.
Oct 23, 2009 | 1997 Volkswagen Golf
The spray continually drips
you can replace spray head by unscrewing underneath the sink and bringing to home depot or Loews and match to new one and reassemble
Jul 07, 2009 | Kohler K-15176-PT-7 Coralais...
Kohler 5988 Sink leaks from soap dispenser spout (?) when dishwasher is running
Hi.. Its a breather or "vent "and its clogged. Remove the drain tube under the sink that runs from the vent to the connection on the drain( under sink). Clean vent and replace. Please send me some Positive feedback if I've help. Thankyou!
Jan 21, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Headlight adjustment
the screws for adjusting the headights are right next to the lights, they are phillips heads and are for adjusting the side to side,
the adjusting screws for the up and down, are on the bottom of the headlights, and they are a small hole in the grill trim, these lights need a pretty long skinny screwdriver with a phillips head
Aug 17, 2008 | 1996 Suzuki Sidekick
Soap Dispensor does NOT open.
This is almost always a dispenser problem. The dispenser is replaced as a unit. you can reach it by removing the Phillips screws around the inside of the door and lifting up the inner door panel. The dispenser's frame is held in place with tiny (1/8 in or 5.5mm) screws.
Mar 11, 2008 | Dishwashers
Kohler Tanager K-6491-2R-7 Black Self-Rimming Kitchen Sink Logo
60 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
