Question about Weather King Heating & Cooling
The WeatherKing Forced air heater stopped working in my house. The thermostat could turn it on in terms of sound but when I looked at the heater, all I saw is the pilot light. No air, hot or cold, was being forced through the hour vents. Other than to remove the cover, I did nothing but now the pilot is off and there is no sound. I checked the house electric breakers and nothing was flipped off. This is a natual gas forced air heater made in 1983, model # GUWHE075A-D4C with 75000 input BTU per hour and a "limit = 160" noted on the heater ID tag.
    Sergeant:
    Novelist:
  • 185 Answers
You will need to relite the pilot if this is a standing pilot furnace........If this has an electronic lite for the pilot then cycle power to the furnace and set thermostat to heat. and retry sequence. Once you get the pilot to lite then watch it to see if the main gas comes on. if it doesn't then you need to check and see if you are getting 24 volts to the gas valve with a volt meter. If you don't feel comfortable with doing this then you will have done everything that is simple. You will have to call a service tech. Problems that it could be are gas valve, limits not closed, ignition control board, main limit open because the blowor motor locked up or motor has open winding or run capacitor open.
Posted on Jan 02, 2011
6 year old colman furnace codes 1 blink ignition failure. Turn heater off at thermostat it cycles and heatsd house restarts a few times. alot of clicking noises and codes again a few cycles later. works...
I had the exact same issue and replaced the control circuit board, igniter, flame sensor, and thermostat just to discover the real problem was a rusted out Roof Jack. (The exhaust pipe that goes through the roof. The inner fresh air pipe was rotted out so the furnace was sucking exhaust gases in which would not support combustion. Have your's checked.
Oct 24, 2013 | Coleman Propane Forced Air Heater...
Coleman echelon 9.T furnace will not turn on. Red light blinking
sounds like it is the pressure switch try jumping it out on some models you fool the heater in too working or see if the tubes are blocked , there should be some codes on the front panel or the fan panel
Apr 27, 2010 | Coleman Propane Forced Air Heater...
Weatherking furnace is starting and stopping
This just sounds like a couple of problems. First, your blower is designed to only turn on once the heat exchanger heats up, so the flame will be on for a minute or two before the blower starts. it sounds like your blower is cooling down the heat exchanger too fast and causing it to shut off so it can warm up again...check blower speed for heat, it should be the lowest speed (black wire). Blue=medium speed, red= high speed. second problem could be your flame sensor rod is calcified, you just need to locate this and clean it off with some fine sand paper.it is located in the flames near the burners. Also change your filters, for proper air flow through your heat exchanger.
Oct 28, 2009 | Heating & Cooling
First floor of house is cold
The thermostat will turn your furnace on and off to satisfy the temperature setting at the location where the thermostat is located. If you move the thermostat to the first floor and set the thermostat at say seventy, it should keep the furnace on until the temperature near the thermostat hits seventy degrees.
Feb 06, 2009 | Honeywell Focus 6300B 5-2 Days...
Short cycling..continually..minimal heat
Is this furnace standing pilot or electronic? if standing pilot turn power off then take t-stat off wall and connect the wires labeled r and c together and see if that keeps furnace working. If electronic check flame sensor you can check flame sensor buy cleaning with steel wool. if that doesn't work then try t-sat.
Jan 21, 2009 | Coleman Propane Forced Air Heater...
My furnace works intermittently.
You may have a dirty flame sensor. There are a number of other possible causes as well. Rheem/Ruud/Weatherking furnaces also have problems with the connection on the blower deck.
The flame sensor sometimes must be bypassed around the MOLEX CONNECTOR in the deck due to humidity.
Hope this helps.
Matt
maxhtcl1@verizon.net
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Matt
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
I have a monessen LPG fireplace and the blower motor has seemed to stop working. it has a variable rotating switch on it. dont know if anyone knows where this problem is on most models like this?
The problem is likely the fan motor for the forced air blower, which means the entire blower needs replaced. The description of the problem is the same problem we had approximately two years ago when our motor was still under warranty (less than a year old). In our case the motor was replaced without charge. However, the same problem has happened this year which is extremely disappointing since we only run the fireplace from December to April intermittently because it is only a supplimental heat source for the house. You can either look up the model number and part number and order a replacement over the web (less expensive if you are DIY and know what you're doing) or see if the local LPG supplier can repair the part or replace. Good luck.
Dec 06, 2008 | Stoves Monessen Variable Thermostat...
Heating & Cooling Logo
196 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
