Question about Amana ARB8057CSR Bottom Freezer Refrigerator
The control arm that controls ice making broke off of the ice maker in the back in other words the plastic broke so there is no anchor in reat for control arm. can i fix this in anyway other than replacing the whole unit?
  • Amana Master
  • 43,501 Answers
You may be able to buy replacement parts...I would check that before replacing the whole unit....
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Jan 02, 2011
Ice maker control arm has broken and ice machine keeps making ice. How do I stop the icemaker? And, then, how do I fix or replace the control arm (which appears to have snapped at the point that the arm...
Good day,
You will have to remove the ice maker. Usually 2 screws or clips on top and one screw on the bottom, as well as the plug that supplies the electrical power.
Since you'll need a new arm anyway, I would suggest you take the ice maker to any decent sized appliance parts house, and see if they'll pull the the old stub out and install a new control arm.
If that doesn't work, you'll need to replace the whole ice maker.
If you want to see if you can remove the stub yourself, unsnap the front cover. You'll see a semi-solid state type board. It is held in with 3 screws. Remove those, pull the board off, and inspect the area we are talking about. You might be able to get it out, but if not, go back to my first suggestion.
Oct 11, 2010 | Amana ARB9059CS Bottom Freezer...
Ice maker overfill
The metal off/on arm may be disconnected. A full bin should keep the arm in the up position and shut off the ice maker.
Remove, then re-insert the metal arm in the back of the ice maker control head.
Make sure that a full bin of ice activates the control arm.
You may need to buy a replacement arm that is longer so that the ice catches on the arm.
May 20, 2009 | Jenn-Air JCD2295KES Stainless Steel
GE Artica PSS29NGNA no ice is being / no water flow on ice side
It is possible the water control valve on the back of the refrigerator is defective. When the thermostat in the ice maker tells the water control valve to ope after dumping the ice. Try filling the ice maker with tap water and let it freeze and cycle one time. It is also possible that the fill tube for the ice maker has frozen shut because of the slow continious flow of a leaking water control valve. You can try to clear the ice with a hair dryer, but if the control valve continues to let water buy will have another damaged ice maker. The part number for the water control valve is WR57X10032 and you can enter parts numbers and model numbers on the search feature at the link below. Let me know how thing are and if you were able to get this under control, I am here to help if you like, sorry I just today saw your post, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 18, 2009 | GE Refrigerators
Ice maker does not stop making ice
id say this could be the bucket thermostat which cuts out when enough ice has been made this will need to be replaced
Apr 13, 2009 | Refrigerators
Amana ARB8057CSR Bottom Freezer Ice Maker Arm is broken & stuck
If water still continues going to the Ice Maker unplug the pair of wires on the back of the refrigerator that send water up to the ice maker. Now I see I am a little late answering your post, because I just happened to run across it. I was not here when you first posted the problem. Just let me know if you still need help, Thanks Sea Breeze
seabreezehvac@yahoo.com
Dec 18, 2008 | Amana ARB8057CSR Bottom Freezer...
Magic chef MCIM30TS table top ice maker shovel breaks
I took 4 small nails, cut them to the proper length, heated them up with a lighter, and pushed them into the plastic creating 4 metal posts that the motor could push against. Just did it and it is working. Not sure for how long.
Nov 21, 2008 | Eastern Tabletop 7002 Stainless Steel 24...
Ice maker not working
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 06, 2008 | Refrigerators
Ice Maker not making ice
replace the icemaker is the best solution , or possibly jst the control module
Jan 14, 2008 | Jenn-Air JCD2389G Side by Side...
check to see if there is a bin switch one that checks for the amount of ice in the bin..replace or check that the nozzles arent blocked.
Nov 05, 2007 | KitchenAid Superba Architect KSCS25INSS...
Amana ARB8057CSR Bottom Freezer Refrigerator Logo
105 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
