Question about Kenmore 36 in. 33212 / 33214 / 33219 Gas Cooktop
Burner ignitions keep sparking when electrical source is on.
  • Kenmore Master
  • 8,220 Answers
One of your spark switch contacts is welded closed. Burner ignitions keep sparking when electrical - themobilian_653.jpgYou must take a wirethemobilian_654.jpg
from each one till you find the bad one. Here is a video
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 02, 2011
Jenn-Air CG206B. All ignitors don't spark or click. How would I know if it is the Spark Module or the Spark Ignition Switch. And cost if possible for parts and labor. Thank you.
one thing to be sure is there power to the range. if you can light the burner with a match your gas is good, If all burners are affected it can be a broken wire, power source, or spark module.
always unplug electricity before attempting to repair on any electrical appliance
Sep 07, 2017 | Jenn-Air Cooktops
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
When i turn on a burner, it lights, but all 5 igniters continue to ignite
I have the same problem all but one burner. When using the other burners the igniters keep sparking after being lit. What do I replace?
Oct 04, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Ignitors are not working
Nov 17, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Kitchen gas 4 burner cooktop
i think all igniter switch are grounded,i request to call expert technician to repair it, or uf u want u open the cooktop to see the igniter swicth at konb control area,clean one by one using thinner,remember switc off the plug first.
Aug 03, 2008 | KitchenAid 31 in. KECS100 Electric Cooktop
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
Kenmore 36 in. 33212 / 33214 / 33219 Gas Cooktop Logo
89 people viewed this question
Top Kenmore Cooktops Experts
jdthefixer
mcgsp
Level 1 Expert
Kolbrun...
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
