Question about Sony SDM-HS74P/S 17" LCD Monitor
Monitor ont stay on - Sony SDM-HS74P/S 17" LCD Monitor
  • 11,361 Answers
It can be bad caps in the power supply, bad backlights inverter circuits, bad lamps (black screen).
You will have to open it up and troubleshoot it.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SONY and other monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 03, 2011
How to clear Huawei ONT data?
Clearing ONT data is similar to restoring factory settings for an ONT. Use either of the following methods to restore factory settings for an ONT:
Choose System Tools > Restore Default Configuration from the main menu on the web page and click Restore Default Configuration.
Hold down the RESET button for a long period of time (longer than 10s) to restart the ONT with factory settings.
Mar 30, 2018 | Huawei Cell Phones
Can the ONT HG8310 configure SNMP by it's self?
No, Huawei ONT HG8310 can't configure SNMP by it self. It belongs to A class ONT which can only configure SNMP by using OLT U200NMS Huawei ONT Thunder link com
Mar 19, 2018 | The Computers & Internet
Does an ONT Support Routing?
Query the ONT nameplate to determine whether an ONT supports routing. If "gateway HGU" is marked on an ONT nameplate, the ONT is of the gateway type and supports routing. If "bridging SFU" is marked on an ONT nameplate, the ONT is of the bridging type and does not support routing.
Apr 19, 2016 | Cell Phones
I have a Samsung 920NW monitor. We moved office and after the move the screen shows "auto adjustment locked" after I put my computer on. I have noticed that the keep getting this message when i...
Hello sadiek, in the moving processs some one must of press one of the setting buttons at the bottom right in front of the screen if you press the first ont from the left "MENU" you will find in that menu a page to "unlock" the auto adjustment
Hope this helped, Pierre
Aug 03, 2011 | Samsung SyncMaster 920NW Monitor
After turning on the hard drive and monitor the monitor screen remains dark, no display. The blue monitor on button is lit.
Try it with another PC to make sure it is not PC or cable problem, if it still does not work, then you should look for bad solder joints ont he 4 toroid indcutors leads, blow transistors, bad caps. Please see my pictures here:
http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
Basic LCD monitor troubleshooting guide:
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Nov 05, 2010 | HP Pavilion F1703 17" LCD Monitor
Window screen is smaller then the monitor. it is on the
For presice adjustments of VGA input run the Auto Ajustment Software on the CD
Additional image quality improvement use the clock and clock pahase controls of the monitor to fine tune the image
Clock increase or decrease the value to minimize any vertical bars or stripes visible on the screen backgroung
Clock phase increase or decrease the value to minimize video distrotion or video jitter
  • allow the monitor to heat up before adjustments
  • use the adjustment pattern application provided ont he CD
  • select OSD menu to select image control and change clock or clock phase
  • Incase of any error restore factory settings select the OSD menu and select factory reset and select yes
Feb 25, 2010 | HP 2159M Monitor
Cannot get sound to work. Until recently we used
I am presuming your monitor has built in speakers you wanting to use. If so you need a male 3.5mm to male 3.5mm cable. Connect on end into to audio in of the monitor and the other to the green audio out socket ont he pc.
If im wrong in assuming that, leave a comment and i'll get back to you.
Nov 23, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
How to use a sony tv as a monitor?
Change the resolution on the second monitor if you ont have the 2nd monitor on your pc , Clik ON DESKTOP PROPRERTY ,SETING'S amd see the 2nd screen rezolution. and make it smaler on the second ,you will be able to keep bouth screen active the monitor and the main screen of laptop.
Jan 19, 2009 | Toshiba Satellite A15-S129 Notebook
Monitor
may be a technical problem..
contact u r retailor......
u have problem inur moniter at power section
ont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 20, 2007 | Compaq Presario 5000 PC Desktop
Sony SDM-HS74P/S 17" LCD Monitor Logo
110 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
