rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
www.nationalserroscotty.org/resources/
dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
I have a dometic 2 door refridgerator and it has been working weel and then when I went to open the door it smells horrible like amonia and a couple of soda cans inside exploded, now it wont run and when you try to run it with doors closed it has a horrible amonia smell. Is it easily fixable or is it simply time to replace? Are these repairable?
Jerry
Dometic RM2652, freezer gets cold but fridge will not get cool at all. got same runaround from Dometic, not under warranty....
jeremy
