Question about InFocus ScreenPlay 4805 Multimedia Projector
Dark haze left side of screen about 4 to 6 inches wide only in the wider screens not in the native
    Problem Solver:
  • 10 Answers
Its a Light Tunnel failure. Go to www.avsforums.com and search for 4805 Light Tunnel. There are instructions to open the PJ and repair the Tunnel. Also, I posted a DIY replacement option in lieu of fixing the very fragile tunnel.
http://www.avsforum.com/avs-vb/showthread.php?t=1304694
Posted on Jan 07, 2011
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
Vertical blue transparent line plasma
Check for loose or dusty flexible connectors. (Please take care to switch off TV and remove plug from the power outlet and discharge high voltage capacitors before you do anything on the PCB) Apply cleaning oil in connectors wherever possible and remove and reconnect it a few times. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Nakamichi VU50P 50 in. HD-Ready Plasma...
I have a 20 inch monitor that the screen is off center.The picture is blank 2 inches on the right and part of the left is missing.
I am guess your have a CRT monitor. There should be a menu button or knob on the monitor. Press it and a menu should come up that will allow you to adjust the position and size of the screen display.
If you have an LCD monitor, the resolution of your desktop is smaller than the screens native resolution. There sould be a button marked "auto" press it and it should correct it. If not, find the desktop screen resolution section in your operating system (control panel) and make sure it is set correctly. If it is wide screen, set it to 16:9 and then set it to whatever has the word "Native resolution" written beside it.
May 14, 2011 | Soyo Computers & Internet
Rca 62 inch projection the screen is a little wider.cant see some things on botton and sides
Sounds as though you have the set in zoom format. Check your remote for a screen format button and switch it to wide or normal format. This button may also be labeled as "Aspect" for aspect ratio which is the ratio of of width to height. Older sets had a ratio of 4:3 and the new wide screen sets are 16:9. In zoom format the pic. is expanded and pushes some of the pic. off the screen display area.
Nov 10, 2009 | RCA Televison & Video
Red haze on right side of the screen
It is usally the component board in the back. It is giving out 5 volts less than it should.
I had the same problem with my Samsung and I called them and the guy came out and opened the back on the tv and just simply swapped some a circuit board over .
The haze will also spread as it did on mine the longer you wait .
Aug 10, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Blue Haze comes out the left side of screen top to bottom about 3 or 4 inches.
What needs to happen is three specific voltages need to be adjusted on the power supply, You need to set the Ve voltage to 100v, the Vset voltage to 188V and the Vs voltage to 190v. Monitor the set for 24 hours, if haze doesn't come back the unit is considered repaired. If haze returns, then the problem is with the panel itself and wouldn't be worth it to replace because it will cost more than the tv cost you originally
May 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Picture is off kilter on Samsung HLM5065W
It is a setting in menu just play with it you will get it wright.
Oct 25, 2007 | Samsung HLM5065W 50" Rear Projection...
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
InFocus ScreenPlay 4805 Multimedia Projector Logo
423 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
