Question about Whirlpool Duet GHW9150P Front Load Washer
The door on my front loading whirlpool duet is extremely difficult to open and close. What can I use on the hinge to make it open and close easily? The model number is WFW9750WW.
    Problem Solver:
  • 14 Answers
WD30 stinks too much, use some 3-1 oil.
Posted on Jan 02, 2011
Door is locked, wont open
remove bottom acces panel 1/4 screw sometimes torx bit ubplug washer reach in on non hinge side against doorshould be door lock latch assymbley, bottom of latch assymbley is a round plastic end thats spring loaded ,pull downward and open door replace door lock assymbley
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Can the door be reversed? ie open from left to right-----hinge on right side If so do you have instructions on how to do it?
Due to the shape of the washer door, and how it seats against the control panel, the door cannot be reversed on the Duet washer. There are no cut outs along the door opening to accommodate the door hinge screws and the door latch on opposite sides. The Duet DRYER, on the other hand, CAN be reversed. This may be an alternative configuration for you. Let me know if you want to know how to reverse the dryer door.
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The hinge on the washer's door is very stiff, noisy, and tough to open & close. The washer is only 4 months old. How do I correct it?
give it a good splosh of "WD40" and work it in till it free's off or better still call out the people who sold it to you as its still under warranty??? i hope! and get them to fit you a new door hinge for "free!" after all this washer should last for years and years not just a fuw months
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have whirlpool model 9450 dryer. Is it possible to change the door opening from hinged on the right side to hinged on the left side?
It advertises the door as being reversible. Sorry I'm not sure how to accomplish this, but maybe check for an online installation manual?
Jan 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool front load duet door hinge is rusted how do i replace
use some wd40 on it and a steal wool pad and it will take the rust away is a few months
Sep 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool gold door falls open during cycle
You can probably get away with getting just hinges for the door if it is not bent also check the latch if it doesn't look broken the just go for the hinges.
Jan 11, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Door wont latch shut
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
194 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
