Question about M-Audio BX5a Speaker
Where do I find a replacement woofer for a bx5a monitor
Http://reconingspeakers.com/product/m-audio-bx5a-woofer/
Posted on Apr 05, 2014
No sound from woofer behringer truth monitor b2031
first check woofer (end wire problem )
remove woofer from circuit
test with 1.5v battery cell touch parallel woofer lead neck
if disturbance sound come from woofer
woofer is ok
Apr 29, 2014 | Behringer Truth B2031 Other Dj Equipment
Audio bx5a tweeter
Tweeter just may need to be replaced. Is all the sound coming only from the woofer?
Apr 04, 2014 | M-Audio Audio Players & Recorders
How to replace capacitor on M Audio bx5a speaker
http://mr-ives.blogspot.nl/2011/09/mending-pair-of-m-audio-bx5a-monitors.html
Apr 20, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
Sounds as if the woofer is blown. seems t be a vibrating noise. this will be the third time fixing this problem.
get some higher rated speakers as this will happen time after time, or you could turn the bass down lol
Apr 08, 2011 | M-Audio BX5a Speaker
So I've kept my Studiophile BX5a Deluxe monitors in good shape, but I noticed that every sound I tried to generate via Ableton Live on my Mac, a buzzing sound would accompany the sound. For example, I...
See if you can isolate the buzz to one woofer or tweeter. If a woofer, gently and evenly move the cone in and release to feel / listen for scraping. If you notice any scraping, the voice coil could be shot - a small bobbin of copper wire may have deformed andis now rubbing. Occasionally if a speaker is dropped, the magnet can shift, which will then rub the coil.
In any case, if there is coil rub that causes the buzz, you need to replace that driver.
If the buzz is electronic in nature, assuming these are the powered versions, a qualified service tech will have to diagnose and repair.
Jan 06, 2011 | M-Audio BX5a Speaker
I got a pair of bx5a What do i need to connect
Here is your resolution that how you can connect your BX5a to PC.
well I had provided some pics attached in that I had marked and given some information follow that accordingly and you will be able to connect it your PC.
But you need XLR code through only you can connect it to your PC.
If you still have nay other problems regarding same or any other do reply me.
Naiven.
May 24, 2010 | M-Audio BX5a Speaker
Bx5a monitor speakers
Check the capacitor, if its swollen or rusty it needs replacing, also check the fuse.
Jun 22, 2009 | M-Audio Studiophile BX5 Main / Stereo...
Need woofer for B2030A
Check the watts and size on your old woofer and go to radio shack and get a repacement woofer with the same wattage and size.
Radio shack make great replacement speakers and woofers.
Feb 14, 2009 | Audio Players & Recorders
No sound from M-audio BX5a monitor
I have a pair of BX5a monitors hooked up to a video editing suite. One of the monitors is off. They are powered to a working electrical supply. They are driven off a Mackie DFX-6 with a 1/4" unbalanced connection. No blue light on the monitor, no sound or hissing on that...
Jan 31, 2009 | M-Audio BX5a Speaker
M-Audio BX5a Speaker Problem
Not sure i can help with the led problem but i just fixed a hissing problem with one of my BX5a monitors. It developed a hiss when on (both tweeter and bass) and a very loud thump when switched off. I found a slightly swollen power filter capacitor on the internal board. They are the two biggest black capacitors, labelled as 25v 6800uf. Only one of these was bulging. The tops of these should be totally flat. The indented X on top of the caps make any bulge easy to spot. Worth opening it up and having a quick look. I could only find 35v 6800uf caps at my local electronics store but they did the job ($3 each). I swapped both out and it's now working great. An easy DIY fix, just be sure to always have the power cord unplugged before you put your hands anywhere near the guts of the thing. Hope it helps.
Sep 17, 2008 | M-Audio BX5a Speaker
M-Audio BX5a Speaker Logo
431 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Carlos L. Burgos
Carlos L. Burgos
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
