Question about HP Compaq (PCXAVCZ) 19" CRT Monitor
Using Windows 7... When turning PC on the screen flashes "Out of Range" I have tried opening PC in Safe Mode and Video Mode but i still get the flashing sign "Out Of Range" I think i have to change the screen resolution but how can i do this if i cant see the screen? All comments welcome, thanks for your help x
  • houpmin lass Jan 02, 2011
    Monitor Model MW19E-AAA
  • 97 Answers
It sounds like a hardware issue. Try hooking it up to another monitor(if available), it sounds like it need a new video card.
Posted on Jan 02, 2011
    Thanks for your comment, how could this have happened? i get the normal start up screen but as soon as i select safe mode or video mode it goes into out of range? xx
  • Anthony Gallo Jan 02, 2011
    Well, It is possible, however unlikely, that you have a virus. You can try running restore CD's on it.
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
Oct 15, 2012 | Soyo Computers & Internet
Emachine 1352 no video no BIOS screen no grub after loading unbuntu 12.04 beside Windows 7
ubuntu is down grading your graphics to suit your screen
if you reset your cmos then try booting into safe mode you should be able to play with your graphics settings
May 15, 2012 | eMachines EL Computers & Internet
I changed my os from windows xp to windows 7...and i am using amd sempron (tm) processor 3400+ 1.80ghz..and 40 g hard disk..then the windows start up wont start normally. pls help!
Try hitting F8 just after your bios splash screen, before it would show the windows logo.
Select, boot in safe mode with networking.
Once you are in windows 7 safe mode, you can install any required drivers. This might prevent it from hanging on the next normal boot.
You can type in the run dialog CMD. This will open a command terminal. Type "SFC /scannow" without the quotes. This will tell windows to verify it's files. Let it complete, then reboot normally. Hopefully the problem will be resolved!
Mar 25, 2011 | Computers & Internet
When attempting to start my computer this morning it took me to the safe mode screen ("We apologize for the inconvenience but windows did not start successfully. A recent hardware or software change...
open your computer in a safe mode then save important files in pen drive or some removable drives....or scan it in safe mode with updated antivirus......or updade windows or repaire windows using installation process...........this will definatelly works..........
Nov 13, 2010 | Computers & Internet
I reset the resolution on the computer (big mistake) and now I cant see the screen in order to reset it back. The screen turns all blue with two messages and a flash of the windows screen (windows 7). The...
Boot up in safe mode and selct VGA support, then set the video resolution to your Princeton VL2018 native resolution mode (1680x1050 @60 Hz)
See more here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Hopefully you monitor doese not have the same problem (bad caps) just like the other VL2018 as shown in my pictures here (but it will fail for sure later on):
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Jun 12, 2010 | Princeton Digital VL2018W Monitor
When I try to use my 17'' Soyo monitor with Windows 7 program the screen turns black and then ''out of range'' wording is all I get on the monitor. I have tried booting in safe mode, set the resolution to...
When you power up the compute press F8 key then enter in :"Enable vga mode" then go to display property and set screen resolution to 1024*768.
Then check .
If still same then enter in safe mode and uninstall graphic driver then start computer normal mode then install graphic driver.
Also in safe mode go to start->run type in run "chkdsk /r" then press ok then press "y" then restart computer then it fix and recovers error on harddrive.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 23, 2010 | Soyo Dymond DYLM017A 17" LCD Monitor
When i turn it on it says out of range and i have a black screen
Hi, The reason behind the out of range (frequency of monitor) because the video display adapter is trying to set resolution more than what the monitor (screen) is capable of. In this case, try to boot your computer in Safe Mode using F8 function key while starting your computer. Once you are in safe mode, try to decrease the resolution of monitor to the lowest resolution level and apply the settings. Now try to boot computer in normal mode once again, you will get the settings which you have applied in safe mode. Adjust the screen resolution accordingly till the settings work with the monitor (screen).
Cheers!
Mar 01, 2010 | Microsoft Windows XP Home Edition
Black screen comes up "windows did not start successfully...." choose from safe mode, safe mode with networking etc Last known Configuration or Start Windows Normally. Computer then tries to...
You should opt Safe Mode:
  • On the black screen just navigate throug up and down arrow keys.
  • Goto Safe Mode and press enter.
  • It will boot your system in safe mode.
If the boot is success full:
  • try to remember any software or hardware you recently installed/change. Then remove/uninstall that software/hardware. Also remove some device driver like Video/Audio driver and make re-start. and try to normal boot. If success then install your audio/video.
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
Apr 20, 2008 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
