Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
Heater starts up but quits after a few seconds
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
Download this "service manual" and see pages 18 - 21 for troubleshooting procedures:
http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
IT can be a dirty photo cell window, a bad ignition module, a mis-aligned photo cell, improper fuel pressure, dirty or clogged air filters, restricted fuel flow, or the fuel cap is not vented.
Thanks for choosing FixYa,
Kelly
Posted on Jan 02, 2011
My 1992 buick regal engine cut out when i pressed the heater switch on .now it just cranks but wont start(turns freely).can you diagnose the problem.
look for a blown fuse since as soon as you flipped on heater it quit ,ck ecm fuse,listen for fuel pump when you first turn key should run for a few seconds
Dec 18, 2014 | 1992 Buick Regal
I have a Co-Op torpedo heater, kerosene, model C50A. It starts and runs about 5 seconds then quits. There is spark at the plug, and it appeared it was trying to flame but the air was blowing too hard.
These things are extremely sensitive to pressure adjustments. They usually cannot be set precisely without a manometer or very low resolution pressure guage.
Google reddy heater for a very detailed description of what the adjustments are and how to properly adjust them. It may cost you a few bucks for a proper guage, fittings and a few inches of tubing.
Nov 20, 2014 | Heating & Cooling
RUNS AND QUITS
You could try replacing the ignition coil. If it's failed, then it may run ok for a few seconds, but as it heats up it fails. Trying to start again immediately will be too soon for the coil to have cooled down. Leave it a few minutes to cool down and it will run again, but only for a few seconds again.
Hope that helps
Jan 03, 2014 | kawasaki 2011 Teryx 750 FI 4x4 Sport
60,000 btu Reddy torpedo heater starts, runs for few seconds and quits. Substituted electric eye and control panel, cleaned air intake, still same action.
legal7,
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, how to fix it and where to get the parts.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 19, 2011 | Heating & Cooling
Heater does not work
temp control actuator,may be called the door blend actuator
Feb 03, 2010 | Hyundai Motor 2004 Sonata
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
When engine is started, heater door makes clicking noise for 20 seconds and quits. When engine is shut off, heater door makes clicking noise for 20 seconds and quits. Door makes clicking noise when heat is...
Your air temp control blend door actuator is failing, that is the part u call a heater door, it is a gear driven miniature drive, the gears are jumping teeth making the noise, it will stop working very soon.
Apr 24, 2009 | 1998 GMC Blazer
2002 Envoy XL, heater motor runs and quits, after a few seconds runs again. It just started this.
it may be the speed control resistor as well, u didn't mention the speed related part.
Mar 27, 2009 | 2002 GMC Envoy XL
Reddy heater 70,000 with factory thermostat will run a few
Set the pump pressure. If correct check the nozzle. Desa recommends annual replacement.
A worn nozzle creates a spray pattern, where a good nozzle creates a fog. With a coarse spray pattern poor combustion results in an off color flame, . The photocell doesn’t like the color, sends a signal to the computer which shuts everything down. That’s the job of the electronics.
Dec 12, 2008 | All-Pro Forced Air Kerosene Space Heater...
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
100 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
