M audio microtrack 2496
I thought about trying a new card which is in line with what your thinking...the only problem with your suggestion is I don't have any files on the current card..I delete them once I transfer them to my computer. Any other thoughts? Thanks
    Genius:
  • 2,035 Answers
Please note when you buy a card you need to check the compatibility and max size your player can support ,,, I saw the posting and your problem was solved ......
Good luck...
Posted on Jul 09, 2008
Hi, i have an m-audio 2496 sound card and a yamaha mixer but the card doesnt record my sound fro my microphone.. pleaseeeeeeee help
Not sure what OS you are using, but here is an article with some ideas on how to fix sound recording problems in Windows Vista.
http://www.pcauthorities.com/multimedia/how-to-fix-sound-recording-problems-in-vista
Mar 09, 2010 | M-Audio Audiophile 2496 PCI Digital Audio...
Won't record
I suggest that you to select Reset to Factory Defaults in the System menu to soft reset reset the unit or by pressing Delete and the power button and holding them down to hard reset. Good luck!
Dec 14, 2007 | M-Audio MicroTrack 24/96
Microtrack screen is on and frozen
I was able to clear the same issue by removing the CF memory and erasing it using a USB card reader connected to my PC. I erased all the files and reinstalled the card in the Microtrack. Works fine now, must have been a corrupted file even though it only contained two mp3s I had recorded earlier.
Dec 19, 2008 | M-Audio MicroTrack 24/96
Reinstalling new control panel in DELTA 246
Make sure all fragments of the original programme are uninstalled before installing a fresh driver.
Mar 09, 2017 | M-Audio Audiophile 2496 PCI Digital Audio...
M-audio 2496: computer is asking to restart
check for virus
get a good virus software. I suggest AVG it is free.
Oct 13, 2008 | M-Audio Audiophile Sound Card
Jolting sound in NEW computer
try to find a good tech guy, its just easy fif you find somebody to fixed. From now just use it with your usb, from now on tll you can find somebody to fixed your new staff.........
Jul 26, 2008 | M-Audio Audiophile 2496 PCI Digital Audio...
Maudio microtrack 2496
can you try another card on it? this would seem to be mainly a card problem I wonder if there is a software update for the device available I will look into that.
Jul 09, 2008 | Audio Players & Recorders
This is suppose to hold hours of recording time and mine only holds a few minutes. How do I increase the time?????
Two things to try: make sure you have a big enough memory card for the intended format and recording time. I suspect you are trying to use the 16MB Compact Flash card that came in the box. A 1GB card will record much longer than the battery life in the Microtrack 24/96, even when recording 24-bit stereo in WAV format. If you have a smaller card, and want long recording times, use an MP3 format. Using the MP3 encoder, monophonic recording, 128K bits/sec, 44.1K samples/sec, you should be able to record over 16hrs of audio on a 1GB memory card. Same card, WAV encoder, 44.1K samples/sec, stereo, 24-bit audio will produce only a little over one hour of recording time. With the 64MB card that came with the recorder, the most you can record using WAV encoding, 24-bit audio, 44.1K samples/sec, is a little less than 4 minutes. With 16-bit audio about 6 min, and with mono and 16-bit audio about 12 min. With WAV, 24-bit audio, mono recording yields 7:52.
Nov 07, 2007 | M-Audio MicroTrack 24/96
Apple Mac 9600/350 problems
Try moving the PCI sound card to another PCI slot. On standard PC machines the IRQs are limited to 15 and many cards require their own, not a shared one. (start from the lowest going up... Leave the graphics card in the top slot (if PCI as well)
Oct 05, 2006 | Apple G3 Beige Mini Tower&8600/9600 (p/n...
 Grubhead
Grubhead
