Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What is the problem code dL on the Cabrio washer mean?
    Problem Solver:
  • 14 Answers
The computer does not recognize the lid has locked if it has. If the lid is not actually locking, the motor in the actuator is most likely culprit. You may contact me for more info.
Posted on Jan 02, 2011
  • Susan Hurley Boyles
    Susan Hurley Boyles Apr 24, 2011
    my washer is saying dl and i can see u say something about a magnet but cant see the rest of how to do it. can u post and tell me what to do i have 5 children and NEED my washer please help
  • 171 Answers
SOURCE: whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
the dr
  • 447 Answers
SOURCE: Whirlpool washer Cabrio WTW6600SB1
Its the Rotor Position Sensor very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
57 varieties
  • 1653 Answers
SOURCE: washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Posted on Oct 02, 2009
SOURCE: error codes
I keep receiving the error code F02, usually during the last rinse cycle. Any idea what it means?
Posted on Jan 14, 2010
localwonder
  • 6784 Answers
SOURCE: my cabrio washer shows a code HC...what does this
HC will flash when the hot and cold inlet hoses are reversed. Make sure your inlet hoses are connected correctly. That should correct the issue.
Posted on Jun 29, 2010
Testimonial: "Thanks for the prompt help!"
WHIRLPOOL CABRIO DL ERROR
The DL is a door lock error but it can also mean an error with communication to the main control board o
First try to unplug all your connections to the main control board and plug them back in and try it again.
Sometimes a wire harness just may be loose.
If that does not work.
You need to replace main control board .
SAM ANDERSON
Sep 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirpool Cabrio says dl when i start the machine what does it mean? And how do i fix it?
Hi
Thanks for using FixYa. Error Ld or dl means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Im getting a code of dl when i start it up...than it just peeps and nothing else happens
dl means door lock error you have to replace the door lock switch cheapest supplier might be marconeappliance parts
Aug 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
WASHER WILL NOT SPIN dL KEEPS COMING UP
dL error - means open door lock switch with motor running, what you need to do is unplug unit for 30 mins, then try again
Jan 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting a DL on the top load washer
The Kenmore Oasis and Whirlpool Cabrio washers are essentially the same. Following is the Whirlpool Installation and service manual for their Cabrio washers.
The DL indicates a problem with the door lock mechanism. See the section on troubleshooting and display codes.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
Dec 21, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
CABRIO WASHER
DL or F 83 is a door lock issue. Make sure the light is off before opening the lid and also check where the lock is for build up a gunk.
Aug 03, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code dL
its a door lock faliure all the error codes are in your use and care guide
Mar 25, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
2,212 people viewed this question
Dan Webster
Dan Webster
Sal De
