Front load washer (Kenmore model # C41-52-00) water will not drain out and cycle finishes with water still in drum.
  • Steve Barrington
    Steve Barrington Jan 02, 2011
    Do you hear the pump motor run or make noise?
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Sounds like the filter needs cleaning/ or pump partial blockage....
Posted on Jan 02, 2011
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
I have a Kenmore front-loading washer. It
The problem is commonly attributed to either a leaking water inlet valve, or a pressure switch malfunction. The following link explains how to diagnose and repair the problem yourself:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I've included steps on how to replace each defective part and parts resources if you need to order anything. If you have any questions, please let me know. I hope this helps you.
May 02, 2010 | Kenmore 44102 Front Load Washer
Washer is not draining at end of cycle-puddle in washer at end of cycle -sears kenmore front loader 3 yrs old
Some of that is normal, if you turn the drum around you will here water. Mine do it also.
Feb 13, 2010 | Kenmore 44102 Front Load Washer
My washer won't drain near end of cycle. Motor
The problem will be on the main board or the power supply board of the machine might have some problem kindly the check the wire lines as well
i do not think that drain pump is having any problem
Dec 30, 2009 | Kenmore 42822 Front Load Washer
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
Won't finish spin/drain cycle. was beeping and
long drain? remove lower cover on front..3 screws across bottom edge. there is a screw-on cover to a clean out. has a screen in there and may be clogged. prepare for a lot of water..u might lean it back against the wall to limit the mess. clean out is white plastic right up front.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Aug 06, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
