Question about Zojirushi CD-JSC30 Electric Kettle
Need rubber gasket. Where can I purchase one and can I install it myself?
    Genius:
  • 1,467 Answers
No sure of U/ S supplier you could try espares.co.uk or get some material and make your own Gasket as I would do if im stuck...
Posted on Jan 02, 2011
The rubber gasket on bottom of gas tank where fuel line exits is torn and leaking. The valve is fine.
You cannot just buy that gasket, but will need to purchase a new Fuel Tap Petcock.
You can purchase it here: http://www.generatorguru.com/northstar/
Aug 04, 2015 | Northstar Electrical Supplies
Torn door gasket
it is possible for you to change it
it depends on where you are then could point you in the right direction
Feb 08, 2014 | Miele W4840 Front Load Washer
Ap-125 homelite gas watwer pump pull cord replace
few years late but here: guessing your problem area is the impeller blade? remove impeller blade by turning clockwise ( i put a screwdriver in the pull cord fin to stop shaft). Then remove spring around rubber gasket behind blade (then rubber gasket pulls off shaft. everything else just UN-bolts. Just figured it out myself today.
Jan 01, 2013 | Homelite Plumbing
Oil spotting on the wash, what can i do?
It is probably not oil. Its from a rubber gasket that is slowly dissolving inside. It has to be replaced before the machine will have a leakage. I´ve had the same problem myself. Using high-quality detergent, (usually tablets) that is less aggressive to rubber will extend the lifespan of the gasket in the future.
Jan 10, 2011 | AEG 24 in. Favorit 60870M Free-standing...
I want to change the valve gasket. I see 2 bolt on the top of it can i do it for myself. im wondering maybe there is some parts attach to it. mitsubishi galant 79 model.
That two bolts is the one holding the valve cover and the air filter housing.
No worries, just remove the bolts, and remove the old gasket around the cover.
Upon installing new rubber gasket, make sure it is clean. Put a silicone sealant around the canal, where the new rubber gasket would be placed, not too much sealant.
Put the new gasket, and now you can put back everything as you have removed it.
Hope that seals everything!
Thanks for using Fixya!
Dec 10, 2010 | 1986 Mitsubishi Galant
How do I install the front rubber gasket on a Duet HT
The following link explains step-by-step how to change the door bellow on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The first three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back with your MODEL NUMBER and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful.
May 20, 2010 | Washing Machines
OIL LEAK
Take the leaking filter off and inspect the rubber gasket. If it is damaged in any way discard it and purchase a new one. Take a small amount of clean oil and with your finger put a light coat of oil on the entire rubber gasket. Install the new filter and hand tighten 1/4 turn after it makes contact with the receiver. If your used filter gasket is ok clean the gasket and apply oil just as with a new filter.
Jan 01, 2010 | 2000 Kia Sportage
My door rubber gasket ripped on front loading neptune washer. my husband is handy, could he replace it himself?
Yes he can replace it himself. Just write down the name, model, serial, and product number to take when you purchase one. You may even have the manual that has the part number for the door gasket.Before you install the new gasket, soak it in a tub of hot water which will make it much more easier to install, for about 1 and 1/2 hours. Good Luck.
Sincerely, shastalaker7
Oct 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Zojirushi CD-JSC30 Electric Kettle Logo
268 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
