My thermostat as working great yesterday, this a.m. the display screen is blank. Does it use batteries?
  • 472 Answers
Some use batteries and some do not...if it is blank or say -ac then you have most likely lost 24 volt power which originates from the inside heating unit... some units do have a fuse installed for this emergency inthe heater unit..make sure you replace it with the same size if it does... if it does not the you may have burned out the low voltage transformer in the heating unit which is usually caused by a short in the low voltage wiring somewhere. if this is a heat pump system and only happened in the heat mode then most likely the short is on the outside unit....
Posted on Jan 03, 2011
Blank Screen
Remove and install new batteries, if displays reprogram. if no display replace thermostat
How To Install Programmable Thermostat The Home Depot
Jan 20, 2016 | Televison & Video
Thermostat is working, but display is blank
My thermostat used to go blank when heating. It was caused by the overheat protector inside the heater. That switch cuts the power to the heater and the thermostat. The heater could also be burned out. If it's a 24Volt system, the power supply could be bad.
Oct 13, 2014 | Heating & Cooling
The main screen on my Casio G'zOne Ravine (C751)
Let it charge for 24 hours before trying again. Battery may be too weak to light up the display yet.
Sep 24, 2013 | Cell Phones
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
Chronotherm III Thermostat Completely Blank Screen, No Heat
One of two things either the disply has gone out which is likely as it is a common failure for that thermostat or your heating unit is not sending control power. the older chronotherms were system (24volt ac) powered the new hardware/box store units are battery powered. Either way display should not be blank with fresh batteries. to get heat on remove the thermostat jumper or twist together the wire from the R terminal with the wire from the W terminal. note the color of each wire for later reference, heat up house disconnect wires from each other and go purchase a new thermostat
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
LG8300 stuck vibrating continuously, now main screen blank
Sounds like water damage. Are there any red stickers under the battery? If so, then it is water damaged.
Either way, if you are the primary line then Verizon may offer you an early upgrade if your rateplan is above a certain price point (if that's who your on). If not, you can do an insurance claim, if you don't have insurance then you will have to either pay full price for a new one, or purchased a used one.
Hope this helps,
Simon.
Nov 17, 2008 | LG VX8300 Cellular Phone
LCD display has gradually disappeared, now I have nothing. I have had this problem with other sangean products. Is there something that can be repaired? If so where can I send it for repair? Please...
This is a defect in the radio. Reportedly this issue was resolved in later vamps of production, but it still seemed to persist. We discontinued this model due to this exact reason. At this time there is no other solution and the factory can not tell us what the problem was and simply pointed to the LCD.
Feb 20, 2008 | Sangean PRD2 AM/FM/TV Radio
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
