Question about Maytag Neptune MAH5500B Front Load Washer
My washing machine is not draining. It has a code "ND" on it. What can I do?
  • 15,935 Answers
ND = No Drain error.
If the unit is not pumping out the water then I would not think twice about changing the pump.
You can test the wires going to it for voltage when the unit should be in the pump out cycle.
If there is voltage to the pump then it is shot.
If there isnt any voltage going to it then the controller board is likely failed and needs replacement.
Thanks for using FixYa
Posted on Jan 02, 2011
What does error code nd mean?
Hello, Vicky -
Is your washing machine a Samsung? If so, "ND" means "No Drain."
Read the information here:
https://removeandreplace.com/2016/03/22/samsung-washing-machine-error-code-nd-what-to-check-how-to-fix/
If I am incorrect in thinking your washing machine is a Samsung, you can Edit your question and add the make and model of your machine, so I or someone else can find an owner's manual for you and check the error codes for your particular machine.
Dec 24, 2017 | Washing Machines
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Nd code
ND code is "no drain" you probably have debris in the drain pump, the pump probably has a drain plug you can remove to clean it out.
Jun 20, 2012 | Maytag Neptune MAH9500A Front Load Washer
Front load washer
Quoted from Samsung FAQs:
"If your washer is beeping, and the display is flashing "Nd", your machine is showing a no drain condition which is usually related to a backed up drain hose or a clogged debris filter.
Follow this link for more information.
Apr 16, 2012 | Washing Machines
Nd code how do I fix
"nd" code indicates that your washing machine is not draining as it should.
To solve it, check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
Hope this helps.
Jun 07, 2011 | Amana Washing Machines
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Code "nd" on washer. just
If you got a "no drain" error yesterday, and cleaned the filter, did you check the drain lines? Also, make sure the waste pipe is correctly.
Dec 31, 2010 | Samsung Washing Machines
My maytag washer mah-24 have a "nd" msg. which mean "not draining" and now i cannot open the door to take the clothes out. pls. help.
Unlocking the door:
Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message:
"nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Nov 25, 2010 | Maytag MAH2400A Front Load Washer
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
