Question about Sunbeam Ultrasonic Humidifier
I have a Sunbeam ultrasonic humidifier model no. 694 and it is not producing condensate air. I think it may have run out of water the last time we used it.
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
freetek
  • 5568 Answers
SOURCE: Need parts for Sunbeam ultrasonic
I see you have been waiting on a response for some time and I suggest you contact Sunbeam (if you haven't done it already) at their website for Canada:
Sunbeam Canada Customer Service
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Posted on Jan 23, 2009
SOURCE: sunbeam ultrasonic humidifier model 696-12
I want to order this rubber gasket
Posted on Feb 24, 2009
SOURCE: Sunbeam Ultrasonic Humidifier SUL495 quit working
Same problem. It worked for about a week, then gradually stopped producing mist. No solution.
Posted on Dec 04, 2010
Sunbeam ultrasonic humidifier model 694
i have a sunbeam humidifier model 694 i want to know how do i use it
Feb 04, 2014 | Humidifiers
Can I use distilled water in my Sunbeam ultrasonic sul496?
You most definitely can. In fact it's better than using tap water. As it doesn't have all the minerals and chemicals that tap water has, that cause scaling.
Thanks for choosing FixYa.
Sep 09, 2011 | Sunbeam Ultrasonic Humidifier
I HAVE A MODEL #694 AND IT'S PUTTING OUT A VERY SMALL AMOUNT OF STEAM. CAN YOU HELP ME. RON.
You need to run a de scaler like CLR through your machine periodically to remove build up leading to poor performance such as you are seeing.
Jan 06, 2011 | Sunbeam Ultrasonic Humidifier
Sunbeam Ultrasonic Humidifier SUL495 quit working in first week. What may have happened.
Nov 29, 2010 | Sunbeam Ultrasonic Humidifier
The date - February 23, 2010 - 6 days ago, I purchased a Sunbeam Humidifier from my local Walmart - Lake Geneva, WI. I really thought I had made a wise purchase - very quite, and was raising the humidity...
Im not going to recomend a humidifier because I need one myself and have not went shopping yet.
I would like to opinionate an explination on the white haze.
The humidifier is putting moisture in the air -water is much much heavier than the air - water is much much heavier than dust particles also.
therefore my theory is that the moisture is combining with the dust or whatever is already in the air and then eventually settling. perhaps if this is correct you may want to do some checking around in your home or furnace ducking or even furnace filter. The dust could even be coming from a little pin hole in your clothes dryer exhaust hose.
Mar 01, 2010 | Sunbeam Ultrasonic Humidifier
No mist, but i can see a water droplet fountain on the surface
if it's a cool mist unit it will not produce any mist. now if it's a warm mist unit it should. that's normal. it is possible to replace the transducer if it is damage but you are going to have some leakage from it. but the only way to get the transducer mainly is from the manufacturer
Mar 12, 2009 | Sunbeam Ultrasonic Humidifier
Sunbeam ultrasonic humidifier runs but produces no mist
Nov 08, 2008 | Sunbeam Ultrasonic 81696 Humidifier
Sunbeam ultrasonic cool mist humidifer model 700
The Problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck.
Feb 17, 2008 | Sunbeam Ultrasonic Humidifier
Sunbeam Ultrasonic Humidifier Logo
130 people viewed this question
Top Sunbeam Humidifiers Experts
Paul Sikkema
Paul Sikkema
 steve
steve
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
